Node Instances
I have played around with the node Instances and duplicated figures. But when i move any part of
the original figure it moves that same part of the duplicate as well. Is there anyway to make duplicates that
will hold the original pose when i change the pose of the original figure? I thought it would be a good way
to get in several figures with eg. full uniforms but with different poses without having to dress up every new figure
  • Richard HaseltineRichard Haseltine Posts: 111,965
    edited April 2018
    A duplicate should not be inheriting anything from its source after duplication (other than the base geometry, but that is true for separately loaded figures too).
    It would be better to continue the existing dsicussion rather than start a new thread https://www.daz3d.com/forums/discussion/comment/3540451/#Comment_3540451
  • I don't think that is possible because node instances are just that - node instances. You could make the instances into real figures though with this plugin https://www.daz3d.com/instances-to-objects . If you make a node instaces of G3F and run this script then the node instace will become G3F as well but then again you could also just simply load a new figure into the scene.
