How can I use Genesis 3 Female character to Genesis 8 Female?
AD_639100
Is there any tool for using Genesis 3 Female to Genesis 8 Female for charactermorphs? Or how can I use character from Gn3F to Gn8F?
Hello.
I have already play with this and it is not so easy. I think there were a tool/script that you can buys from the daz store that allows you to transfer character morphs from G3F to G8F but i am not sure about. You can look at this thread https://www.daz3d.com/forums/discussion/176271/morphs-from-g3-to-g8 where they discuss that matter.
However i do suggest to do it manually because not matter what tool you use it alwyas (or in most cases) needs to adjust the rigging (bone structure, rotations and so on) so all to work normally.
Generally base mesh is almost the same, JCMs are similar as well between G3F and G8F however G8F have enhancments in bending and feet. So if you transfer body morphs probably you will need manual adjusting.
You can also look here https://www.daz3d.com/forums/discussion/177511/transfer-of-character-morphs-to-g8f-impressions - i wrote some tutorial about that kind of stuff.
Hello dimitarcenevjp_418dde9d63,
thank you for your informations and links. My english is not the best and I hope my Google translation will help correct understanding. THX.
