Image on button
EdpaEdpa Posts: 46
Hi!
I try to do button with image. But now have button with image size and picture as too small icon.
I used this script .What should I add? which strings?
var wDlg = new DzDialog;
var wBtn = new DzPushButton(wDlg );
var pixImage = new Pixmap("c:/2016-07-06_180440.png");
wBtn.pixmap = new Pixmap(pixImage );
wDlg.exec()
Post edited by Chohole on
  • EsemwyEsemwy Posts: 578
    edited January 2017
    I think your image just needs to be larger. Also why are you constructing the Pixmap twice?
    var sFilename = aTextureFiles[i];var button1 = new DzRadioButton( wVbgLayer );button1.pixmap = new Pixmap( sFilename );
    I don't have a push button example handy, but DzRadioButton should be the same.
    Post edited by Esemwy on
    I take it back. This must be something peculiar to DzPushButton. It looks like a bug to me.
  • hphoenixhphoenix Posts: 1,335
    I think you are both thinking a DzPushButton's icon is for image purposes.....it's supposed to be the 'down arrow' for buttons that display a set of options.  Position and size are GUI style controlled.  Look at the definition of the Qt class it wraps (QPushButton) here:  http://doc.qt.io/qt-4.8/qpushbutton.html
    I'm not sure what DS uses for buttons with non-icon style images on them.  It may be a built-in custom widget that would have to be loaded using DzUiLoader....
  • EdpaEdpa Posts: 46
    Thanks guys!
    I thought before about DzUiLoader :)
    But I do not know how I can connect this with the action,with my function.
    I tried this code, but it does not work
    var loader = new DzUiLoader();
    var dialog = new DzDialog();
    var dialogWgt = loader.load("C:/test.ui",dialog);
    connect( dialogWgt, "clicked()", myFunction );
    dialog.exec();
    edited February 2017
    Edpa said:
    Thanks guys!
    dialog.exec();
    I think what you need to do is something like (**untested**):
    var dialog = new DzDialog();var dialogWgt = loader.load("C:/test.ui",dialog);buttonWgt = dialog.findChildOfWidget("theOkButton"); # Find the button by its nameconnect( buttonWgt, "clicked()", myFunction );dialog.exec();
    Hi, Esemwy!
    Your script is running great. Thank you very much. Button name I found in my UI file (my widget) and replace your name  theOkButton.
    Hurrah, now I can create any widgets! yes
    The script looks completely
    buttonWgt = dialog.findChildOfWidget("toolButton"); // Find the button by its name
    dialog.exec();
    A fragment of UI file with Button name
     <widget class="QToolButton" name="toolButton">
       <property name="geometry">
  • Hi  guys!
    I wrote about Vertical slider http://www.daz3d.com/forums/discussion/73311/vertical-slider#latest
    I thought to use the UI file too.
    After example of Esemwy, I tried to come back to this method. But I did not succeed ... Have you tried to do the slider widget?
    If yes, How do you connect the slider with actions? Which signals you used?
    I see strange visualization of the vertical slider in the DAZ. I think that DAZ not support it now. Try to use the QT scrollbar instead of slider. Parameters are similar.
  • YudinEdYudinEd Posts: 90
    edited March 2017
    Other version without UI file - Label on the button
    var wDlg = new DzDialog;var wBtn = new DzPushButton(wDlg );var Label=new DzLabel(wBtn)var pixImage = new Pixmap("c:/image.jpg");Label.pixmap = new Pixmap(pixImage );// Button size must have image size. My image size = 80,100wBtn.width=80wBtn.height=100 wDlg.exec()
    Post edited by YudinEd on
  • TotteTotte Posts: 15,380
    Looking at the docs there is a ButtopStyle Object that is not documented, I guess that has something to do with this....
    Downside is that the image is not default adjusted to pushed/non pushed state, but I like this workaround for the time being
    edited April 2017
    No problem . Simple example :)
    var wDlg = new DzDialog;var wBtn = new DzPushButton(wDlg );var Label1=new DzLabel(wBtn)var Label2=new DzLabel(wBtn)var pixImage1 = new Pixmap("c:/image.jpg");Label1.pixmap = new Pixmap(pixImage1 );var pixImage2 = new Pixmap("c:/img.jpg");Label2.pixmap = new Pixmap(pixImage2 );Label2.hide()connect(wBtn,"clicked()", ButtonClicked)// signals too  "pressed()" or "released()"// Button size must have image size. My image size = 80,100wBtn.width=80wBtn.height=100 wDlg.exec()function ButtonClicked(){Label2.show	()}
    You can control clicks. I usually use the function (for 2 clicks-  even or odd number)
    var a =0;if ( a&amp;1 ) {   false // even click - 1th image}else {   true; //odd click - second image}
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
    I only write the tested scripts. The code works. Check the path to your picture and its name  and slash (correctly  / )
    cheeky
    edited May 2022
    Redacted
