Vertical slider
I don't understand how to do slider (to example enumslider) as vertical.
Please help me with codewink Thanks
  • YudinEdYudinEd Posts: 90
    I probably did not exactly give the name of the post. It should be called "how to make vertical widget?"
    The documentation has for DzWidget
    enum DzWidget::Orientation
    Enumerated orientation types
    Enumerator:
    Horizontal  Horizontal orientation (Left to Right)
    Vertical  Vertical orientation (Top to Bottom)
    In QT there is Horisontal and Vertical too.
    I tried to use as DAZ script variables
    DzWidget.Orientation= Vertical // Any widget DzEnumSlider, DzTabWidget - No errors and no changes!
    I tried too as "vertical" - nothing. What to write instead of the word Vertical ?What am I doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 110,877
    Vertical in your example is being taken as a variable name, with an uninitialised value. To tell the script that you are using the enumeration you need to give it as a member of DzWidget:
    myVScrollbar.orientation = DzWidget.Vertical;
    should work if the syntax is otherwise correct.
    edited March 2017
    var wDlg = new DzDialog;var w = new DzEnumSlider( wDlg)w.orientation = DzWidget.Vertical;w.addItem( "oh" )w.addItem( "my" )w.addItem( "Bob" )w.value = 2;wDlg.exec()
    the Idea is good, but it is not working :(
    Post edited by YudinEd on
    Try
    w.orientation = DzEnumSlider.Vertical;
    or
    w.orientation = w.Vertical;
    Sorry, but there are no changes. I shall try another variants if I'll find :)
    It's possible that scripting doesn't allow for vertically oriented sliders, I can't recall seeing one.
    edited March 2016
    This is another variant - Slider from QT designer in UI format . Screenshot from DAZ.  But I don't now how I can work with this QT slider using DAZ script functions
    QT slider in Ui format
    Post edited by Chohole on
    edited March 2017
    edited March 2017
    I took  scrollbar instead of slider, because vertical slider displayed incorrectly  in the DAZ.
    I found the signals in the QT documentation  - sliderReleased() and sliderPressed(), which work in the DAZ script normally. I am satisfied with such a variant
    var loader = new DzUiLoader();var dialog = new DzDialog();var dialogWgt = loader.load("C:/noname.ui",dialog);Slider = dialog.findChildOfWidget("verticalScrollBar"); // Slider name in UI widgetconnect( Slider, "sliderReleased()", myFunc );Slider.setValue(50) // to set parameter. My default from UI file =0 dialog.exec();function myFunc(){{print(Slider.value)}	// testing	}
    edited March 2017
    I add. You can use signal  valueChanged(int). It's better - parameters change immediately. int constant .  You haven't change it.
  • Mike3DMike3D Posts: 73
    Seems that some methods & properties are not exposed to scripting. We can't get/set:
    - DzWidget::Orientation
    - DzDynamicDividerWgt::ResizeType
    Is this intentional ? Am I missing something ?
    Thanks
