Nvidia 1070 GPU
Are the Nvidia 1070 GPU working with Iray in Daz...or are they still working on that.
Mine is very slow and working at about the speed as the GPU in my old computer.  And it was a
Nvidia 740 GPU
  • GTX 1070s work well using the latest DS Beta.
  • SoneSone Posts: 84
    My new Gigabyte 1070 crashes the DAZ beta. All errors point to iRAY in message fatal error, and 3Delight works to confirm. Trying to figure it out, it's gotta just be me.
    What is your driver version?
    There was an issue that was driver related, so if it's not the latest (from Nvidia) you may want to try that.
    I have and am using 375.95  I think that is the latest one. It doesnt work either with 372.54
    Thanks mjc, ideas are always good and welcome
    What's the log file say?
    If you can't get Studio to stay open long enough to view the log, it can be found in your users/<your user name>/Application Data/DAZ 3D/Studio4/ folder.
    edited November 2016
    I will check that out thanks.
    ****I am running a Phenom II  X6 1100T found this info in the beta thread
    4.9.3.128 - Release Candidate 3 (November 4, 2016) *UPDATED*
    • NVIDIA Iray
      • Integrated Iray 2016.3 beta build; improves support for Pascal generation (10-series) GPUs; requires CUDA 8.0 (see this post for more information)
        • Does NOT currently address reported issues with OS X CUDA Compute Capability <= 5.2
        • Does NOT currently address reported issues with ILLEGAL_INSTRUCTION in libneuray.dll on AMD CPUs that do not support SSSE3 instructions (e.g., Phenom II, etc.)
    Post edited by Sone on
    Here's my story MJC   thanks
    2016-11-28 22:32:52.582 Iray INFO - module:category(FREIMG:IMAGE):   1.1   FREIMG img  info : Plugin "fi_wbmp" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.582 Iray INFO - module:category(FREIMG:IMAGE):   1.1   FREIMG img  info : Plugin "fi_xpm" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.612 Iray INFO - module:category(IRAY:RENDER):   1.1   IRAY   rend info : NVIDIA display driver version: 375.95
    2016-11-28 22:32:52.612 Iray INFO - module:category(IRAY:RENDER):   1.1   IRAY   rend info : Your NVIDIA driver supports CUDA version up to 8.0; iray requires CUDA version 8.0; all is good.
    2016-11-28 22:32:52.620 Iray INFO - module:category(IRAY:RENDER):   1.1   IRAY   rend info : Using iray plugin version 4.4-beta, build 278300.573 n, 06 Oct 2016, nt-x86-64-vc11.
    2016-11-28 22:32:52.895 Iray INFO - module:category(IRAY:RENDER):   1.1   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 6.70725 GiB available, display attached
    2016-11-28 22:32:52.896 Iray INFO - module:category(BLEND:RENDER):   1.1   BLEND  rend info : Plugin "blend render" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.902 Iray INFO - module:category(IRAY_CLOUD_CLIENT:NETWORK):   1.1   IRAY_C net  info : Plugin "iray_cloud" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.902 Iray INFO - module:category(IRAY_CLOUD_CLIENT:NETWORK):   1.1   IRAY_C net  info : Plugin "irt_cloud" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.902 Iray INFO - module:category(IRAY_CLOUD_CLIENT:NETWORK):   1.1   IRAY_C net  info : Plugin "nitro_cloud" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.907 Iray INFO - module:category(IRAY_CLOUD_CLIENT:NETWORK):   1.1   IRAY_C net  info : Plugin "iq_irt_cloud" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.907 Iray INFO - module:category(IRT:RENDER):   1.1   IRT    rend info : Plugin "irt" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.907 Iray INFO - module:category(EIAXF:IO):   1.1   EIAXF  io   info : Plugin "axf importer" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.907 Iray INFO - module:category(ICB:IO):   1.1   ICB    io   info : Plugin "cb_importer" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.912 Iray INFO - module:category(IRAY_CLOUD_CLIENT:NETWORK):   1.1   IRAY_C net  info : Plugin "iray_bridge_snapshot" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.912 Iray INFO - module:category(IRAY_CLOUD_SERVER:NETWORK):   1.1   IRAY_C net  info : Plugin "iray_bridge_server" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.912 Iray INFO - module:category(EEMI:IO):   1.1   EEMI   io   info : Plugin ".mi exporter" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.916 Iray INFO - module:category(EIMI:IO):   1.1   EIMI   io   info : Plugin ".mi importer" (build 278300.573, 06 Oct 2016) initialized
    2016-11-28 22:32:52.917 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 6.70725 GiB available, display attached
    2016-11-28 22:32:52.918 Iray INFO - module:category(IRT:RENDER):   1.0   IRT    rend info : Resource assignment for host 0 has changed.
    2016-11-28 22:32:52.918 NVidia Iray GPUs:
    2016-11-28 22:32:52.922  GPU: 1 - GeForce GTX 1070
    2016-11-28 22:32:52.922  Memory Size: 7.9 GB
    2016-11-28 22:32:52.923  Clock Rate: 1746500 KH
    2016-11-28 22:32:52.923  Multi Processor Count: 15
    2016-11-28 22:32:52.923  CUDA Compute Capability: 6.1
    2016-11-28 22:32:52.923 Iray INFO - module:category(IRT:RENDER):   1.0   IRT    rend info : Resource assignment for host 0 has changed.
    2016-11-28 22:32:53.120 Total class factories: 2002
    2016-11-28 22:32:53.120 Iray VERBOSE - module:category(IRAY:RENDER):   1.1   IRAY   rend stat : Environment cache size capacity: 5.
    2016-11-28 22:32:53.127 Creating Script Engine...
    2016-11-28 22:32:53.149 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    2016-11-28 22:32:53.149 3D mouse support library could not be loaded.
    2016-11-28 22:32:53.151 Creating Main Window...
    2016-11-28 22:32:53.152 Creating Viewport Manager...
    2016-11-28 22:32:53.261 Successfully created OpenGL viewport for Viewport1.
    2016-11-28 22:32:53.536 Successfully created OpenGL viewport for Viewport2.
    2016-11-28 22:32:53.710 Successfully created OpenGL viewport for Viewport3.
    2016-11-28 22:32:53.892 Successfully created OpenGL viewport for Viewport4.
    2016-11-28 22:32:54.029 Creating Action Manager...
    2016-11-28 22:32:54.039 Creating Pane Manager...
    2016-11-28 22:32:54.310 Successfully created OpenGL viewport for AuxViewportView.
    2016-11-28 22:32:55.614 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2016-11-28 22:32:55.865 Executing startup script...
    2016-11-28 22:32:55.943 Started in: C:/Program Files/DAZ 3D/DAZStudio4 Public Build
    2016-11-28 22:32:55.943 DAZ Studio Started
    2016-11-28 22:32:55.952 Creating Pixel Buffer
    2016-11-28 22:32:56.066 Pixel buffer - Width: 1024 Height: 1024
    2016-11-28 22:32:56.067 Compiling OpenGL Shader...
    2016-11-28 22:32:56.068 Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Shader Program successfully linked.
    2016-11-28 22:32:57.621 Compiled C:/Users/sone/AppData/Roaming/DAZ 3D/Studio4 Public Build/temp/shaders/brickyard/{a173c42d-83aa-4a25-8cc2-7332610be9e8}/shader_Surface.sdl...
    2016-11-28 22:33:06.420 Updated metadata for 0 of 1 items.
    2016-11-28 22:33:06.531 WARNING: cloud\dzcloudtasknotifier.cpp(660): sync completed successfully, 1 items succeeded, 0 items failed.
    2016-11-28 22:33:06.531 Metadata update succeeded.
    2016-11-28 22:33:16.959 *** Scene Cleared ***
    2016-11-28 22:33:17.178 File loaded in 0 min 0.2 sec.
    2016-11-28 22:33:17.178 Loaded file: 1969 hondy minibike.duf
    2016-11-28 22:33:17.772 Loaded image dax color.jpg
    2016-11-28 22:33:18.151 Ran tdlmake on image C:/Program Files/DAZ 3D/DAZStudio4 Public Build/shaders/iray/resources/carbon_bump.png
    2016-11-28 22:33:18.710 Ran tdlmake on image C:/Users/evanm/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_22615/runtime/textures/dax color.jpg
    2016-11-28 22:33:18.841 Ran tdlmake on image C:/Users/evanm/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_22615/runtime/textures/dax bump.jpg
    2016-11-28 22:33:36.991 Rendering image
    2016-11-28 22:33:37.118 Iray INFO - module:category(IMAGE:IO):   1.0   IMAGE  io   info : Loading image "C:\Users\evanm\Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_22615\runtime\textures\dax color.jpg", pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2016-11-28 22:33:37.140 Iray INFO - module:category(IMAGE:IO):   1.0   IMAGE  io   info : Loading image "C:\Users\evanm\Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_22615\runtime\textures\dax bump.jpg", pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2016-11-28 22:33:37.144 Iray INFO - module:category(IMAGE:IO):   1.0   IMAGE  io   info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4 Public Build\shaders\iray\resources\carbon_bump.png", pixel type "Rgba", 512x512x1 pixels, 1 miplevel.
    2016-11-28 22:33:37.158 Iray INFO - module:category(IMAGE:IO):   1.0   IMAGE  io   info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4 Public Build\shaders\iray\resources\DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2016-11-28 22:33:37.321 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating geometry.
    2016-11-28 22:33:37.395 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using built-in ray tracing (1.0.0).
    2016-11-28 22:33:37.395 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing geometry.
    2016-11-28 22:33:37.489 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 347k triangles, 1 instance yielding 347k triangles) took 0.093308
    2016-11-28 22:33:37.495 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
    2016-11-28 22:33:37.502 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 16 textures, 0 lambdas (0 unique)
    2016-11-28 22:33:37.503 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.00s
    2016-11-28 22:33:37.503 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
    2016-11-28 22:33:37.520 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
    2016-11-28 22:33:37.520 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
    2016-11-28 22:33:37.520 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
    2016-11-28 22:33:37.520 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
    2016-11-28 22:33:37.520 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
    2016-11-28 22:33:37.527 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1 layer frame buffer
    2016-11-28 22:33:37.533 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
    2016-11-28 22:33:37.533 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Initializing local rendering.
    2016-11-28 22:33:37.584 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):
    2016-11-28 22:33:37.590 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info :  CUDA device 0 (GeForce GTX 1070)
    2016-11-28 22:33:37.590 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
    2016-11-28 22:33:37.590 Iray VERBOSE - module:category(IRAY:RENDER):   1.7   IRAY   rend progr: CUDA device 0 (GeForce GTX 1070): Processing scene...
    2016-11-28 22:33:37.875 Iray VERBOSE - module:category(IRAY:RENDER):   1.6   IRAY   rend stat : Geometry memory consumption: 9.39113 MiB (device 0), 0 B (host)
    535 x 562 - 87K
    Nothing you can do until an update is made...that's why I'm not running the beta, I've got an x4 910.
    Thanks man for confirming, I appreciate it.
