Adding Object to existing Object
Hello!
I want to make an angel and therefore give genesis 3 male some wings. Now I designed the wings in blender. I export the g3m from daz3 with subd=0 as .obj and import it in blender with keep vert oder & poly groups. I positionate the wings in blender on g3m and afterwards export it ofc with correct settings as already seen in:
http://www.daz3d.com/forums/discussion/51207/solved-create-morphs-in-blender-for-daz
I hoped that it will work with Morph Loader Pro but always same warning: Geometry did not match, failed to create morph.
So the question:
Is it possible to add an Object to an other Object using Blender and using it as a morph in Daz3d?
If no is there an other way?
Thanks Sincerely
Gobo
A morph is just the pushing or pulling of existing vertices in the model to create a new shape, you cannot add or remove geometry. Import just the wings in to Studio and rig them, they then can be parented to any figure.
