how do I add background images
using 4.9 and according to docs I just go to file and background...but there is no background option under files, or anywhere else I can see
thanks
  • BeeMKayBeeMKay Posts: 7,019
    edited September 2016
    Check for the Winndow Pane "Environment". It has a background image option.
    Window > Panes (Tabs) > Environment
    I can't make a screenshot now as I'm nor at my PC.
    EDIT: Lifted from barbuit's post from this thread: http://www.daz3d.com/forums/discussion/70305/how-i-can-put-a-picture-designed-by-me-as-a-backdrop
    Lifted from this thread: http://www.daz3d.com/forums/discussion/52356/black-backdrop-on-start-how-to-fix-it
    Post edited by BeeMKay on
  • dracorndracorn Posts: 2,379
    This is how I do it:
    Part I:
    I use Environment and backdrops so often that I have it just below my Content Library Tab.
    Here we have a character with no background.  It is important that your  backdrop and your Aspect Frame are of similar ratio, because the frame will squeeze your picture into that ratio.
    1. Click the down arrow next to Type and click on Backdrop.
    2. Click the arrow box in Background.
    3. Click Browse.
    4. Choose your background file and click Open.
    600 x 750 - 102K
    464 x 433 - 14K
    464 x 249 - 28K
    376 x 160 - 28K
    463 x 141 - 24K
    Post edited by dracorn on
    Part II:
    5. This is what I mean about the picture conforming to the Aspect Frame.  Since it is not 360 degrees, it will always appear the same no matter how you rotate your view.
    Rendered with the background.
    I like to use this with free pictures from Pixabay and others, or with my own backgrounds I created in Photoshop.
    809 x 820 - 140K
    600 x 750 - 195K
  • l_stowel_stowe Posts: 172
    I was going to say, add a plane and then add the background image to that. But maybe the other way is better. In the past I've added two planes, two textures to build up walls of a room
  • AJ2112AJ2112 Posts: 1,417
    I like adding backgrounds to planes, for versatility.  I can move the background with the prop yes
    I have also tried planes as well, but abandoned them because when the plane is too close to your subject, it casts a shadow onto the plane.  Looks kinda weird when there's a shadow on your forest or city.
  • OstadanOstadan Posts: 1,133
    You could make the plane a light emitter, not to illuminate anything else, but to kill shadow.
