how i can put a picture designed by me as a backdrop?
p05p05 Posts: 25
Hi, the question is...i have a nice photo and several designed by me and i wish to put as background into a scene in DAZ 4.9
How i can do that?
thanks
  • barbultbarbult Posts: 27,599
    You can add a primitive plane and add your photo in the surfaces tab. Or, you can go to the environment tab and add your photo as a "backdrop". Make your plane or your render settings size match the aspect ratio of your photo to avoid stretching.
  • p05p05 Posts: 25
    Excuse me, where is the environment tab?
    thanks
    edited January 2016
    For me it is in the same pane group as Scene. If you don't see it, use the Window menu shown below to open it.
    580 x 868 - 60K
    Post edited by barbult on
  • p05p05 Posts: 25
    thanks a lot!
  • NovicaNovica Posts: 23,925
    edited January 2016
    Open that tab like Barbult showed you, then drag it and attach it next to one of the other panes (I have mine next to Content Library) Then whenever you want to change out backdrops, it's easy.  When you open Environment, you'll need to click to open the submenu and select backdrop, then click to Browse to an image. I can't open mine up right now to screenshot as I am installing products and I don't have the studio open when I am doing that. Just be aware you will be clicking to get to where you choose the image.
    Post edited by Novica on
  • dracorndracorn Posts: 2,382
    Environment works best for me - items in your scene will cast a shadow on a plane. Looks a little funny if it's the sky with a shadow on it.
