Official Announcement: HiveWire 3D to publish Animals through DAZ 3D
Yup, I remember each of those instances.
Yep, I remember those AND my Zygote Victoria :P. I actually remember when Posette and Dork were IT....lol. I've been doing this stuff waaaay too long ;).
Laurie
Ahhh, I was still playing in Bryce back then, so only hung out in the Renderosity Bryce forum, because DAZ didn't own Bryce at the time.
Victoria 8 discount offer code won't workYup! VICTORIA-8 all caps and no spaces is what I tried and it worked. Thanks Richard!
Victoria 8 discount offer code won't workdoesnt work for me either, spaces, no spaces, all upper case, capatalized....
Maybe because I have a non-US keyboard my - in Victoria - 8 is not the dash the makers of that discount code used? I see only 1 dash on my keyboard though.
Genesis 3 to Genesis 8 Pose Converter (Commercial)Well, first of all I've purchased that nice little script, although I missed the promo with the 40% and discount on other pose sets. Bummer! Anyhow, will definitely use this one much more than the older ones I also have. But before I unleash my inner pose conversion beast, a couple of questions to do things right:
Metadata yes/no?
Well seems activating that option will slower the process. What does it do? Are the poses then available in the Smart Content Pane? And are they sorted in for G8F so that are showing up once I work with an G8F? Another question regarding the target directory for the converted poses. If I organize the converted poses manually later on and change folders, does that break metadata/smart content links?
Couple poses, like G3F/G3F or G3F/G3M
Have some pose sets with multiple figures. Guess if it's two G3Fs this should work but what if there are poses for G3F and G3M in a folder. Does the script leave the G3M poses alone? From my first tests it at least says it is also converting G3M poses? So can a savely select a folder of "mixed" poses or should I just manually select the G3F pose files?
Victoria, Olympia and the rest of the pack
Is it safe to assume that the script works properly on dedicated poses for certain G3F based figures as well, although maybe demanding some tweaking later on?
G3F and things
Have some pose sets which include poses for props (motorcycle, furniture, weapons etc.). Again would it be safe to just select the folder for conversion or would the script mess up with prop poses and should I therefore just manually select G3F poses in such folders?
Thanks in advance for any heads up. Guess my G8F pose folder will be quite full in the near future ;-)
I’m confused about what the “Wear Them All” product does.Okay here is a really quick render after using the ultra templates. doesn't look like there is any distortion that I can see, I used a different shader (don't mind the clashing of color or design, I was just adding something that would show a distortion in the pattern if there was one. This is what I did. Loaded G3F - Loaded V4 Happily Ever After Skirt with G3F selected. Right clicked on skirt since the autofit dialogue did not come up and chose fit to. When the auto dialog came up, I chose the Genesis 2F clone because that is all that was available (not sure if its because I have the bare bones on my computer at work, its a good possibility that the field will populate with a Victoria 4 Clone if I had all of my stuff on this computer) and then chose SY ultra big skirt and hit enter. This is the result. The top has also been autofitted, again via G2f simply because I don't have the other products loaded onto my work computer.
Victoria 8 Coupon not workingNot working for me either. That said, I'll consider buying Victoria 8 when they get us Michael 8.
Victoria 8 discount offer code won't workI have see a banner when I log in offering an extra 40% off of VIctoria 8 if I use the code V I C T O R I A - 8 (that's how it's printed) but when I enter it in it says it's invalid. I've tried it with and without spaces. Does anyone know what I'm doing wrong?
Victoria 8 Coupon not workingany possibility of getting this fixed?
Official Announcement: HiveWire 3D to publish Animals through DAZ 3DYup, I remember each of those instances.
I'm so old, I remember when HiveWire started up as an ALTERNATIVE to Daz.
I'm so old I remember when the founding members of HW3D were part of the DAZ team ;)
. ..I'm so old I remember the "home brewed" forums, vouchers instead of coupons, 1.99$ PC items, the original galleries (that awarded vouchers if your pic was accepted), and monthly freebies with no purchase required.Yep, I remember those AND my Zygote Victoria :P. I actually remember when Posette and Dork were IT....lol. I've been doing this stuff waaaay too long ;).
Laurie
...OK OK, you got me beat.I'm so old, I remember when HiveWire started up as an ALTERNATIVE to Daz.
Heh, I'm so old, my Victoria came from Zygote...
Distance squared fall off (LightX free plugin)The different skin tones are due to me correcting the legs and feet but not the rest (just me being lazy!) in the shaders. Don't worry about it, it is maybe something strange about my setup and it is easily rectifiable so I don't think it is worth anyone losing any sleep over!
Well, you created the new Victoria 4 foot lamp !
Official Announcement: HiveWire 3D to publish Animals through DAZ 3DI'm so old, I remember when HiveWire started up as an ALTERNATIVE to Daz.
LOL!!
How can I make my models look "wet", like sweaty wet and also having finished a Dive?If are using Victoria 8 settings, you can get a wet look by increasing the "Dual Lobe Specular Weight" and/or increasing the "Dual Lobe Specular Reflectivity".
How can I make my models look "wet", like sweaty wet and also having finished a Dive?Hi Folks:
Recently I purchased a wet map app, but when I double click it, nothing appears to be different on it. Do I have to go through a series of adjusts in settings or paint the figure. Anyway I've got a deadly unit of Frogwomen whom I'd love to make "wet looking" but still haven't figured out how. All suggestions and wisdom cheerfully received.
PS Marcius I LOVE Lt. Parker, next to Victoria 8 shes my new favourte lady. Please thing about doing a Super Pro version with wetsuit that fits and full body camoflage. Tried putting a wetsuit on her. She doesn't seem to like it as her arms immediately pop out of the sleeves. Cheers and thanks everyone. lol
*Closed* RRRR A long time ago or Far far away ContestPull #1
#984 Classic Pin-Up Standing Poses for Victoria 6 (#16555)
#4057 Novel Romance Poses for Genesis (#16311)
#5371 Songs in Stone (#10640)
#2241 Freya For Olympia 6 (#17807)
LB1: #1592 Domina - Character (#18413)
LB2: #6508 Weapons Series 1 - Spears and Pole Arms (Rendo)
LB3: #6002 The Streets Of Asia 2 (#13717)Random numbers generated Jul 10 2017 at 7:40:46 by www.psychicscience.org
Free educational resources for parapsychology and psychical research.
This is scary!It looks like www.psychicscience.org knew my whereabouts
Now lets see how to pull this one off, pun intended
Scary indeed...
The older generation: Victoria 2/3, Michael 2/3 and their children rendersIt is most fitting that I come after mmalbert cause she and I are working on the Art Doll thing. Here is the first rendition of my version of an art doll. It is a weight mapped Victoria 2 with converted iray textures on her. The following list are the currently available freebies. Sure wish Runtimedna was back up and that Traveler would reoffer all of the neat clothing sets he made for Vicky.
Environment: Background Cloudy Skies Backgrounds-01-Part 6 Of 8 by pixlgirl.
Environment: Birds Flock 3D Model by Forester.
Environment: Plant Vase flowers N050317 by Andreo.
Girl: Character: Texture Natty-V2 Clone by Casette.
Girl: Clothing: Gee String Zip_String for DAZs Victoria 1 by Xorron Andreas Dirks Goblin Desgin.
Girl: Clothing: Neck Chain Tassel for curtains N050112 by Valery Korneev.
Girl: Clothing: Neck Ruff V4 Renaissance Neck Ruffs-- UPDATED!! by Rosemaryr.
Girl: Clothing: Shoes Fetish Pumps V4 by Reiko-Kano.
Girl: Clothing: socks BAT KneeSocks by BatLab.
Girl: Hair Updo Hair SR1 by Kozaburo. Removed the bun. Changed the texture to white.
Girl: Hair: Bows Pillows 3D Collection by 3DBar.
Girl: Poses Hand Pose Vol. 1 for Victoria by HarpoonVolt.
Shader: Clothing Pd-Daz Studio Soft Leather Shaders by Parrotdolphin.
Shader: Skirt: Hair bows Iray Nobiax Shaders by kaz42.On A Clear Day You Can See Forever
nicely done composition! great element choices and visually striking!
(and love those sox! - thanks for providing the link - what a treat!)
--ms
Michael 8Hah, so you're saying Victoria isn't expensive, but it's her wardrobe that'll get you?
Like most women, right? ;) LOL
Laurie
I'm a gentleman, and wasn't going to go there. Although I did pretty much point the way, didn't I?
But I do celebrate the differences between the genders!
well now days there's more than two genders as well as genderless which when you think of it daz was the first there with the first genesis figure
Novica & Forum Members Tips & Product Reviews Pt 9Just a few I did last week to test hair I am packaging (from Rendo.) These are both on Genesis, using the V3digitimes Iray Converter for Genesis for the skin. Man, these pose stiff compared to G3F.
This first gal is Morgan for Victoria 4.2 and Genesis and the Rendo hair is Leiko. I added smoothing. Watch out for these files, they have My Library in the file structure. Mine are Content>whatever.
