CARRARA CHALLENGE #63: There be Dragons..... WIP
have you seen them snapdragon seed pods!..... freaky stuff that.. imagine if........
When the local Nuclear Physicist has the weekend off, he gets down and dirty in the garden. This weekend however he never imagined what would happen when he accidently mixed some blood & bone with some gamma radiated snapdragon pods and inhaled the seeds
his green thumb hobby was about to take a nasty turn
The SnapDragon Scientist
modelled the garden and ornaments and props ( dragon, owl and dragon's breath plant ) modelled the snapdragon head and used it on Pumpkin Jack along with some Carrara fur, used some free plants from some PA here at Daz3d and then did a little postwork in PSE2022.
snapdragon head with some morphs
Animate a Material \ Texture transition In Daz3D iRay.I've asked a similar question for Carrara and use it quite often. That said, I'd like to Do somethiung similar in Studio. The shaders are there but, I'm stuck on the animating side.
Any advice would be great? This Forum has yet to fail me.CARRARA CHALLENGE #63: There be Dragons..... WIPPart 1 - The Saga
This is a tip of the hat to Planet of the Apes - without the time travel twist. Instead, there was just boring old evolution. Lizards were slow to evolve, but 66 million years is a long time. :) They eventually developed language and technology. No, they don't breathe fire, but they can shoot fire weapons.
Lizards developed a natural caste system based on species variations, much like the apes did in POTA.
Humans (Sapiens) came along just about when lizards realized that killing each other for food was going to insure mutual destruction. As creepy as those warm-blooded Sapiens were, they made a tasty stew!
Characters include M3, F3, G1 and G2M, and some morphs like Dragonfolk that I have not used before. Fire effects are Jepe billboards. The building is from an old Stonemason set. The flying lizards are the Moorland Dragon. The flame weapon is actually called the Steam Dragon, and it is available on Rendo.
Carrara processes include Text and Surface Replicator. At this point, GMIC is always part of my initial setup.
No postwork, as usual.
Edit - I added a new version in the attachments below, but kept the old so that following posts would not be empty.
Can I install Carrara 8.5 on Drive D on my computer?Jan_Scrapper said:
I am running out of room on my C: drive.
An easy fix is to install Carrara 8.5 (Paid version in 2016) on my computer's D: drive. Carrara is showing to be 207 GB in my Control Panel which is hard to believe, but ok.
Has anyone ever done this?
Thank you so much for your help!!
I also run dual hard drives, but only for a bootable backup of Drive C: using Casper from Future Systems Solutions. My Carrara program is about 1 GB, there is something wrong with your 207GB. I'm pretty sure I can run Carrara from my backup hard drive - that's the whole point of Casper, a completely identical drive, bootable. But a first step might be to offload your C: Drive to external devices - USB drives, flash drives, DVD's, anything.
Can I install Carrara 8.5 on Drive D on my computer?I am running out of room on my C: drive.
CARRARA CHALLENGE #63: There be Dragons..... WIPBunyip02 said:
Steve K said:
WendyLuvsCatz said:
I consider DAZ studio a useful Carrara plugin and it really doesn't take up much space.
I finally broke down and installed Daz Studio Pro 4.2. Not (yet) to get DUF files into Carrara, but just to render a product that comes in DS and Poser format. Neither Poser nor Carrara gave the great quality of renders in the product samples, e.g. the "ELITE" glass sign above the revolving door (see attached). As always, I floundered around in DS, new to me, but finally got it to do some great renders. The bad news is it took Iray to do it, about 60 to 90 minutes for a 1280x720 image. (!) Not gonna do any animations at that rate, but backgrounds for Carrara animations look promising.
Thanks Wendy et al.
As a Carrara plugin it does have it's uses !!!
Two things: I'm learning that you have to make sure a DS/Poser product comes with Iray textures, some are added only later. Also, for some products (not all), I think I can get pretty close to the Iray render using a Poser format in Carrara. Takes some work in the Texture Room using Carrara's great library, and some lighting work (as always with Poser products in Carrara), but pretty good. And probably feasible for animations. Even if you use the Iray render as a still image establishing shot. Following all that? There will be a quiz.
Carrara Sale Email Message Alert threadUnifiedBrain said:
Howie's Carrara products are starting to show up in clearance. Got one yesterday, and there are several today.
I assume that most people here have them all, but I have very few.
don't wait too long
yes I think I have everything Carrara by him except the Yu;e cottage which I never wanted
quite a few of the DAZ studio sets too
PAs are pruning their Carrara and other not DAZ studio content so don't expect them to stay in store forever
Carrara Sale Email Message Alert threadHowie's Carrara products are starting to show up in clearance. Got one yesterday, and there are several today.
CARRARA CHALLENGE #63: There be Dragons..... WIPHeadwax said:
here's two I worked on last week and yesterday - not happy with either
First one I decided to make a dragon vase so I took Dragonfolk into 3d builder and for some reason did a boolean using a cut sphere then brought it back into Carrara and hit it with random metallic shaders
rendered with HDR and caustic, the patterned backgroind is from AgeOfArmour's tremendous art studio, you can also see it in the reflections as well
The adulterated one
and the unadulterated one
I like it, suspect that your internal critic is giving you a hard time about it though.
Only thing that looked odd to me was the Dragonfolks tail sticking out of nowhere.
Headwax said:
edit: not sur whay the dragon folk didn't work in Carrara out of the box for me :(
Will check them out - have not used them in Carrara before ...
Worked fine for me !
CARRARA CHALLENGE #63: There be Dragons..... WIPWendyLuvsCatz said:
I have used them but you may need to uncheck limits before loading
thank you @WendyLuvsCats - sorry didnt see your comment
CARRARA CHALLENGE #63: There be Dragons..... WIPhere's two I worked on last week and yesterday - not happy with either
The adulterated one
CARRARA CHALLENGE #63: There be Dragons..... WIPedit: not sur whay the dragon folk didn't work in Carrara out of the box for me :(
CARRARA CHALLENGE #63: There be Dragons..... WIPUnifiedBrain said:
Headwax said:
Finally had achance to sit down with carrara
Dragonfolk - had to use the daz studio plugin to get them into carrara , a character called grim, the spheres on the ground qwere replicated then turned into reall instances so I could move them, lots of lighting via caustics,
two fogs and some background gemoetry made with an online programe by Andrew Marsh Polyhedra Generator (andrewmarsh.com) - he has a few things worth looking at
the big sphere behind the two grims is reflecting the sky
Another great image to add to your long catalog of great images.
Not sure why you needed DS to load Dragonfolk. I think it is basically uses Millennium Dragon 1?
I'm also impressed that you got the dorky flame prop to look so artistic. :) Awesome overall lighting, reflections, esthetics, and a very creative use of the Polyhedra plugin you mentioned.
Thanks for reminding us what happens when you use your full power as an artist. I am way more inspired by this than I am inspired by push-button AI.
thank you UB :) _ Ah for the flames thing I inverted the alph map on a hunch and addede the texture map to the glow channel - I like cuatics because they often give you unecpected results - also tone mapping in post brings out the darks that are too darl sometines - I used the normal map and took it into Affinity photo and used that to play with the lighting
Where can I find some good Carrara Tutorials?CARRARA CHALLENGE #63: There be Dragons..... Voting threadYOU can enter up to 4 carrara renders/animations including in an external renderer for which there is a carrara plug-in (eg LuxRender, Octane) with your interpretation of the theme.
DATES to Remember:-
WIP Thread Opens: Saturday, 09 July 2022
Entry Thread Opens: Saturday, 06 August 2022
Entry Thread Closes/Voting Begins: Saturday, 20 August 2022 23:59:59 CST (GMT-6) 3 September 2022 23:59:59 CST (GMT-6)
Voting Ends: Saturday, 27 August 2022 23:59:59 CST (GMT-6) 10 September 2022 23:59:59 CST (GMT-6)----------------------------------------------------------------------------------------------------------------------------
Sample entry Thread Post
ENTRY # -
ARTIST NAME -
TITLE OF WORK -
LINK TO WIP(S) -
CREDITS -
COMMENTS -
3D Art Freebie Challenge August 2022 - "Sniff, sniff... what's that smell?" - Main Thread Only
From blooming flowers to rotting garbage, from French perfumes to Swiss cheeses, from grandma's cooking to grandpa's socks... this month is all about the smelly, the fragrant, the stinky, the odorous, the aromatic! Wonderful or vile... or perhaps both? The theme of the August challenge is "Sniff, sniff... what's that smell?"
The Rules For This Months Freebie Challenge are:
1. A minimum of (5) Freebies must be included in your image along with Links to the freebies you have used. For an item to be considered free it must be offered as a freebie for the whole month. The exception to this rule is all Daz Bi-Weekly Freebies will be allowed throughout the entire month in which they are free as well as the month following their release as a freebie (For a total of 2 months). Also, if a freebie is broken down into multiple downloads/links/parts (IE like if the freebie is broken down into 3 zips etc...)it only counts as 1 freebie, not 3.
2. There will be a Maximum of 5 purchased items.
3. Base figures (All Gen 2,3,4, and Genesis 1,2,3) as well as their general morphs packs (Morphs++ and similar) do not count as a purchased item or a freebie and may be used as needed
4.Your Rendered Picture must be a new render and postwork is allowed but you MUST include a before and after Postwork versions of your entry in the Entry Thread.
5. All DAZ 3D Programs are allowed (IE Bryce, Carrara, Daz Studio and Hexagon) plus Poser for the contest.
6. All entries are subject to the Daz3D TOS Found Here: Terms Of Service
7. You may enter a Maximum of 4 Entries per month.
8. You may edit your entry as much as you like in the main thread but once it is posted to the "Entries Thread" it may not be further modified. Also, if you edit or add things, be sure you update any links or freebie changes you make.This Freebie Challenge will end August 31st 2022 @ 23:59 Daz time.
*Please Note: Please allow 7 days from the Announcement of the Winners to recive your prize*
If you have not recived your prize, or have any questions, plz contact (ME) Hylas in a PM here on the forumsPost your images and freebie links here for link verification. Once the links are verified, you can post your image and links in Entries Thread for judging.
First Place: $15 store credit from KindredArts
Second Place: $10 store credit from KindredArts
Third Place: $5 store credit from KindredArtsPast Freebie Contests:
October 2015 - TRICK OR TREAT TIME
November 2015 - MEMORIES ARE MADE OF THIS
December 2015 - It's Steampunk at the North PoleJanuary 2016 - The Day After
February 2016 - EleMENtary, my dear Watson!
March 2016 - It seemed like a good idea at the time...
April 2016 - When I Grow Up I Want To Be A Woodland Fairy
May 2016 - From This Hill I Can See...
June 2016 - Dawn of a New Day...
July 2016 - You Did WHAT With That Firecracker!?!
August 2016 - I Don't Want to Go to School!
September 2016 - The Leaves of Autumn Bring ChangesOctober 2016 - Double Bubble Toil and Trouble
November 2016 - I am so THANKFUL I am not...
December 2016 - How'd THAT Fit Down the Chimney!?!January 2017- THE DAY AFTER HANGOVER
Febuary 2017- MAKE HIM/HER PAY FOR IT YOU SAY!!
March 2017 - KISS THE BLARNEY STONE
April 2017 - LET'S SPRING INTO EASTER
May 2017- MAY FLOWERS BRINGS MOTHER'S DAY CELEBRATIONS
June 2017 - BEST/WORST VACATIONS/KID ADVENTURES
July/August 2017 - BAD IDEAS MAKE THE BEST PRACTICAL JOKES
September 2017 - GIRLS/BOYS NIGHT OUT ADVENTURES
October 2017 - MONSTERMASH RehashNovember 2017- Remembering The Fallen
December 2017- Waiting Up
January 2018- The Cement Jungle
Feburary 2018- Love Is....
March 2018- As Green As.....
April 2018-April SHowers Bring...
May 2018-Month Of The Dragons
June 2018-Beach Bum Days
July 2018- Camping Blunders
August 2018- Vacation Disasters
September 2018- Worst Day Of School
October 2018-Annual Monster Mash
November 2018- Time To Reflect
December 2018-Let It Snow
January 2019-Frozen In Time
February 2019-Strange Love
March 2019-Lady Luck
April 2019- April Showers Bring...
May 2019- Spring Flowers
June 2019- Summertime Pin-Ups
July 2019- Pool Party
August 2019- Best Friends forever
September 2019- Turning A New Leaf
October 2019- Monster Mash
November 2019- Playing Doctor
December 2019- Better Than Mistletoe
January 2020- New Beginings
Febuary 2020-Natural Love
March 2020- March Winds
April 2020- Easter Happyness
May 2020- >Flowers
June 2020- A Day At...July 2020- Only At The Circus
August 2020- Cats, Cats, All Kinds Of Cats
September 2020- In The Sky
October 2020- Monster Mash
November 2020- Best Of Friends
December 2020- Holiday Tradations
January 2021- New Years Resalutions
Febuary 2021- Love Is Different Now
March 2021 - Chasing Your Golden Dreams
April 2021-Spring Forward
May 2021- May Mysteries
June 2021- Dream Vacation
July 2021- Wild Wild West
August-September 2021 Science
October-November 2021- How To Repair...
December 2021 - Dressing Up For The Holidays
January 2022 - Around and around and around...
February 2022 - Mysteries of the heart
March 2022- Luck Of The Draw
April 2022 - New Beginnings
May 2022 - Cozy Corner
June/July 2022 - The Secret Life Of...
