Transfer/import ALL maps between programs using Diffeomorphic
This is a hybrid Daz3D/Blender question, because I'm not sure which program is doing it. I've been using Diffeomorphic to import Daz models into Blender for some time now. I've been having an issue where certain models are not importing with all the textures that others may have. For example, on some, it may have toenails, but not fingernails. Others, it has a mouth, but not teeth. Another common one (especially since using G8.1) is the eyes - sometimes the model will have Sclera, Irises, Pupils, and Corneas individually. In others, the Sclera and Irises are one, and no Corneas is present. Is this due to some kind of preset using the model's textures in Daz, or is Blender "losing" the files somehow in transit?
G9 Items on G8Even with clones, they can be problematic, especially dresses. When a conversion with autofit fails I do the following:
Load the figure the clothing originally belongs to and delete all the addons. Dial the G8 clone shape into the original figure and pose as close to G8 as possible. Change clothing to base res and fit to the figure. Hide the figure and export the clothing as an obj.
Load G8 figure, import the obj and fit to G8 using Transfer Utility as normal. Using Transfer Utility again, transfer the morphs from the original item. If the item was dforce, give the G8 one a dforce modifier. Copy the dforce settings from the original to the G8. Convert item to subd and save.
This works for all those figures that you have clones for.
Let's appreciate/discuss today's new releases - ongoing threadSilverGirl said:
MimicMolly said:
The touchable products should have better preview thumbnails, at least. The cropped letters make them skippable because I often don't recognize hair by the names, only by the looks.
Yeah, I was wondering if something messed up on import? Because only seeing part of a title of stylized letters tells me NOTHING (visually) about whether I'm interested or not, and no way am I going to click on all that just to see if I might like it. And it just looks... cheap and ill-coded.
The thumbnails were most likely automatically created when importing the product by cropping the central part of main promo image in the desired aspect ratio. Which doesn't work at all for a lot of wolfie's products which don't use the usual Daz promo format for the main promo.
Let's appreciate/discuss today's new releases - ongoing threadMimicMolly said:
Render starts then IRAY rend error and ends, Render is clearly not done all samples.One thing jumps out, "Geometry import (1 triangle object with 35 M triangles, 1 instance)"... What is that?
DS likes quads better than triangles, and 35 million triangles is insane amount.When rendering, do you use Iray in your viewport as well?
Studio + Diffeo + HEAT + WINEHad a good call with Stav from HEAT and was able to get some things working. After getting Charolette 8 in the T pose and dressed in All That Glitters (at least the dress portion, shoes will come later), she was exported from Studio (under WINE) to Blender 4.0 (under Linux) via Diffeo. Easy Import seems to be the only option, not sure why, but it worked. Downloaded the "Wave Over" animation from HEAT, applied to a new Armature and then targetted to Charlotte. So far, it ain't looking too bad.
This is a screenshot of a frame 66 (of 250) render. Will let the animation render all night. Hopefully Blender will stop crashing.
Rendered in Cycles.
Render starts then IRAY rend error and ends, Render is clearly not done all samples.I lastly assumed it was old drivers, was on 546, but I just updated to the latest Nvidea Drivers (using DDU) as of today but The issue remains. So I am going to come here and ask, maybe there is something I can try because I am seriously depressed that I have made 0 progress all weekend.
I have 2 G8 characters in the scene, interior scene and I thought it initially was because the second character is using the Fantasy Skins 8.1 because it felt like all these issue started after introducing the fantasy skins
G81F and G81M, the Male is using the fantasy skins, I rendered a few PNGs before this where the G81M was not skin colored but now that the G8M is, I am having an issue like this every 2nd or 3rd render, need to restart and reload the scene to be able to render again.
https://www.daz3d.com/fantasy-skins-for-genesis-81-malesScene uses about 10,329MB according to HWInfo, I grabbed the number after the Rendering starts as I know it inflates (went from 3GB to 11GB)
DAZ 3D 4.22.0.16 AMD 3950X 64GB RAM RTX 3090 Windows 11 64-bit
(wish there was a Spoiler/drop-down tag, sorry for the wall of text)
2024-04-09 19:52:44.048 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel. 2024-04-09 19:52:44.050 Iray [INFO] - TRAV:DATABASE :: 1.0 TRAV db progr: Traversing scene. 2024-04-09 19:52:48.907 Iray [INFO] - TRAV:DATABASE :: 1.0 TRAV db info : Traversing scene took 4.857 s. 2024-04-09 19:52:48.943 Iray [INFO] - POST:RENDER :: 1.0 POST rend info : Postprocessing denoiser is enabled 2024-04-09 19:52:48.947 Iray (Scene Update) : Updating LPE labels 2024-04-09 19:52:48.948 Iray (Scene Update) : Updating geometry contexts 2024-04-09 19:52:48.948 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry contexts. 2024-04-09 19:52:48.948 Iray (Scene Update) : Updating geometry 2024-04-09 19:52:48.948 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry. 2024-04-09 19:52:48.948 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph. 2024-04-09 19:52:48.949 Iray (Scene Update) : Retrieving geometry 2024-04-09 19:52:48.949 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0 2024-04-09 19:52:51.352 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 35 M triangles, 1 instance) took 2.403 s 2024-04-09 19:52:51.352 Iray (Scene Update) : Updating motion transform data 2024-04-09 19:52:51.352 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms. 2024-04-09 19:52:51.352 Iray (Scene Update) : Updating section objects 2024-04-09 19:52:51.352 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating section objects. 2024-04-09 19:52:51.353 Iray (Scene Update) : Updating materials 2024-04-09 19:52:51.353 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials. 2024-04-09 19:52:51.682 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 481 textures, 0 lambdas (0 unique) 2024-04-09 19:52:51.682 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (6 light sources with 1089 triangles, 1 instance) took 0.000 s 2024-04-09 19:52:51.683 Iray (Scene Update) : Updating environment 2024-04-09 19:52:51.683 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment. 2024-04-09 19:52:51.691 Iray (Scene Update) : Updating code 2024-04-09 19:52:51.691 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled material code. 2024-04-09 19:52:51.691 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled environment code. 2024-04-09 19:52:51.691 Iray (Scene Update) : Updating textures 2024-04-09 19:52:51.692 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating material textures. 2024-04-09 19:52:51.699 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment textures. 2024-04-09 19:52:51.699 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating BSDFs. 2024-04-09 19:52:51.699 Iray (Scene Update) : Updating volumes 2024-04-09 19:52:51.699 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating volumes. 2024-04-09 19:52:51.699 Iray (Scene Update) : Updating lens data 2024-04-09 19:52:51.700 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens. 2024-04-09 19:52:51.700 Iray (Scene Update) : Updating lights 2024-04-09 19:52:51.700 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights. 2024-04-09 19:52:51.700 Iray (Scene Update) : Updating instance topology 2024-04-09 19:52:51.700 Iray (Scene Update) : Updating flags 2024-04-09 19:52:51.700 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags. 2024-04-09 19:52:51.700 Iray (Scene Update) : Updating backplate 2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate. 2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled backplate code. 2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate textures. 2024-04-09 19:52:51.701 Iray (Scene Update) : Updating decals 2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals. 2024-04-09 19:52:51.720 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate. 2024-04-09 19:52:51.722 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer 2024-04-09 19:52:51.733 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using batch scheduling, caustic sampler enabled 2024-04-09 19:52:51.733 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing local rendering. 2024-04-09 19:52:51.733 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Caustic sampler implies guided sampling. 2024-04-09 19:52:51.739 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using OptiX version 7.5.0 2024-04-09 19:52:51.744 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX for CUDA device 0 2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s): 2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090) 2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering... 2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): Processing scene... 2024-04-09 19:53:02.703 Iray (Scene Access) : Retrieving geometry 2024-04-09 19:53:02.703 Iray (Scene Access) : Retrieving device geometry 2024-04-09 19:53:03.140 Iray (Scene Access) : Retrieving volumes 2024-04-09 19:53:03.141 Iray (Scene Access) : Retrieving textures 2024-04-09 19:53:05.733 Iray (Scene Access) : Retrieving device textures 2024-04-09 19:53:06.143 Iray (Scene Access) : Retrieving flags 2024-04-09 19:53:06.144 Iray (Scene Access) : Retrieving device flags 2024-04-09 19:53:06.145 Iray (Scene Access) : Retrieving lights 2024-04-09 19:53:06.145 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : Importing lights for motion time 0 2024-04-09 19:53:06.145 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : Initializing light hierarchy. 2024-04-09 19:53:06.152 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : Light hierarchy initialization took 0.006 s 2024-04-09 19:53:06.152 Iray (Scene Access) : Retrieving device lights 2024-04-09 19:53:06.152 Iray (Scene Access) : Retrieving section objects 2024-04-09 19:53:06.153 Iray (Scene Access) : Retrieving device section objects 2024-04-09 19:53:06.153 Iray (Scene Access) : Retrieving materials 2024-04-09 19:53:06.157 Iray (Scene Access) : Compiling custom code 2024-04-09 19:53:06.157 Iray (Scene Access) : Retrieving environment 2024-04-09 19:53:06.160 Iray (Scene Access) : Retrieving device environment 2024-04-09 19:53:06.161 Iray (Scene Access) : Retrieving backplate 2024-04-09 19:53:06.161 Iray (Scene Access) : Retrieving device backplate 2024-04-09 19:53:06.161 Iray (Scene Access) : Retrieving decals 2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving device decals 2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving motion transform data 2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving device motion transform data 2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving lens data 2024-04-09 19:53:06.163 Iray (Scene Access) : Retrieving device lens data 2024-04-09 19:53:06.196 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Scene processed in 3.494s 2024-04-09 19:53:06.206 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 102.832 MiB for frame buffer 2024-04-09 19:53:06.211 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 1.969 GiB of work space (2048k active samples in 0.005s) 2024-04-09 19:53:06.211 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Optimizing for cooperative usage (performance could be sacrificed) 2024-04-09 19:53:07.119 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Allocating 1-layer frame buffer 2024-04-09 19:53:07.137 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 73 2024-04-09 19:53:07.184 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00001 iteration after 4.482 s. 2024-04-09 19:53:07.912 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 214 2024-04-09 19:53:07.920 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00002 iterations after 5.219 s. 2024-04-09 19:53:08.806 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 518 2024-04-09 19:53:08.815 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00003 iterations after 6.114 s. 2024-04-09 19:53:09.768 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 874 2024-04-09 19:53:09.777 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00004 iterations after 7.075 s. 2024-04-09 19:53:10.614 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 994 2024-04-09 19:53:10.625 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00005 iterations after 7.923 s. 2024-04-09 19:53:11.689 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1054 2024-04-09 19:53:11.697 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00006 iterations after 8.996 s. 2024-04-09 19:53:12.511 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1104 2024-04-09 19:53:12.542 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00007 iterations after 9.841 s. 2024-04-09 19:53:13.940 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1190 2024-04-09 19:53:13.949 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00008 iterations after 11.247 s. 2024-04-09 19:53:14.695 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1233 2024-04-09 19:53:14.703 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00009 iterations after 12.002 s. 2024-04-09 19:53:15.411 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00010 iterations after 12.709 s. 2024-04-09 19:53:16.236 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1236 2024-04-09 19:53:16.245 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00011 iterations after 13.543 s. 2024-04-09 19:53:17.606 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00013 iterations after 14.904 s. 2024-04-09 19:53:18.449 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 2287 2024-04-09 19:53:18.459 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00014 iterations after 15.757 s. 2024-04-09 19:53:19.694 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00016 iterations after 16.992 s. 2024-04-09 19:53:20.917 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 3357 2024-04-09 19:53:20.926 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00018 iterations after 18.224 s. 2024-04-09 19:53:22.420 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00021 iterations after 19.717 s. 2024-04-09 19:53:24.062 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 4421 2024-04-09 19:53:24.094 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00023 iterations after 21.392 s. 2024-04-09 19:53:25.968 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00027 iterations after 23.266 s. 2024-04-09 19:53:27.380 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 5851 2024-04-09 19:53:27.390 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00029 iterations after 24.688 s. 2024-04-09 19:53:30.188 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: 37.18% of image converged 2024-04-09 19:53:30.206 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00035 iterations after 27.504 s. 2024-04-09 19:53:31.366 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 6994 2024-04-09 19:53:31.375 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00037 iterations after 28.674 s. 2024-04-09 19:53:33.968 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00042 iterations after 31.266 s. 2024-04-09 19:53:36.172 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 9075 2024-04-09 19:53:36.206 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00047 iterations after 33.504 s. 2024-04-09 19:53:39.013 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00053 iterations after 36.311 s. 2024-04-09 19:53:41.663 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 11367 2024-04-09 19:53:41.697 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00059 iterations after 38.995 s. 2024-04-09 19:53:45.040 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: 54.16% of image converged 2024-04-09 19:53:45.040 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00067 iterations after 42.339 s. 2024-04-09 19:53:48.317 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 13478 2024-04-09 19:53:48.350 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00074 iterations after 45.648 s. 2024-04-09 19:53:51.255 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00081 iterations after 48.553 s. 2024-04-09 19:53:54.614 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00089 iterations after 51.913 s. 2024-04-09 19:53:56.216 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 16379 2024-04-09 19:53:56.224 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00092 iterations after 53.522 s. 2024-04-09 19:54:00.537 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: 64.49% of image converged 2024-04-09 19:54:00.555 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00101 iterations after 57.853 s. 2024-04-09 19:54:05.726 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00110 iterations after 63.025 s. 2024-04-09 19:54:07.634 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 20374 2024-04-09 19:54:07.643 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00114 iterations after 64.941 s. 2024-04-09 19:54:11.387 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.5 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Kernel [15] (LensTraceSr ) failed after 2.157s 2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.5 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while launching CUDA renderer in <internal>:908) 2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.5 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Failed to launch renderer 2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Device failed while rendering 2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER :: 1.2 IRAY rend warn : CUDA device 0 (NVIDIA GeForce RTX 3090) is no longer available for rendering. 2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER :: 1.2 IRAY rend warn : All available GPUs failed. 2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: Fallback to CPU not allowed. 2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while initializing memory buffer) 2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: All workers failed: aborting render 2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): [Guidance sync] Failed master device (remaining 0, done 0). 2024-04-09 19:54:11.390 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.390 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.390 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.390 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.392 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.2 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory) 2024-04-09 19:54:11.393 [ERROR] Iray :: Internal rendering error. 2024-04-09 19:54:12.439 [INFO] :: Saved image: C:\Users\***\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png 2024-04-09 19:54:12.451 [INFO] :: Finished Rendering 2024-04-09 19:54:12.560 [INFO] :: Total Rendering Time: 1 minutes 56.55 seconds
Daz to Blender Bridge - Meet the Teamdruc said:
Hi, Is there an option to send Blender files, including the animated parts of Blender props to Daz via the bridge. I'm not a big user of Blender, I only downloaded it years ago because a talented person made several Matt Smith Tardis interiors. I would love to use them in Daz Studio.
The bridge is from Daz Studio to Blender, not vice versa. That said, the current Daz Studio Beta has had many improvements made to its FBX import so it may be worth trying that route.
Daz to Blender - Diffeomorhpic Import PoseHi everyone!
This is my first time posting here so sorry if I miss some details that are required when submitting.
I'm trying to use the diffeomorphic addon to import poses from Daz to Blender but each time I import a pose, I'm unable to edit the character in pose mode.The character was immediately imported with the MHX rig if that helps through Easy Import.
Parts of the rig disappear, and even when I turn them back on in the Object Data Properties tab I just can't move them. The poses import fine, but sometimes they don't and need corrections but I can't change them.
Not sure how to post images in here but this is a link to what's going on:
https://imgur.com/a/QecrTVI
Is there something I'm missing? Thank you!
lilflameWell, guess I already own 90% of the lilflame stuff which made it's way from Rendo to DAZ. So probably need to use the browser extension to hide all those products I own from store listings.
Little finding: Is DAZ using the mature-filter to become a little more "revealing" finally? Don't know if it is just a matter of bulk import which will be curated later on. But there are quite some new lilflame products which showcase the reveal-morphs included with the products not only with clay models but though final renders. Not that I mind the slightest. lilflame's promos are IMO top notch and tasteful, whatever is shown. So I hope it stays that way :-)
Rendo migrations and the risk of duplicate purchasesWhen I buy any 3D product, I download any documentation available about it. That includes freebies. I then put that into my files that mimic Smart Content structure. Yesterday, knowing that I had bought many of Fabiana's products, I looked up the two I wasn't sure about and yep, not purchased yet. So into my cart they went.
Now I am in the middle of adding metadata and the thumbnails, which for some reason DAZ failed to do. Thankfully her Content Library organization is clean and I am working with that to assign the metadata.
And for what it is worth, The Tywill necklace fit G9 easily when I was testing something.
Let's appreciate/discuss today's new releases - ongoing threadI don't dislike Daz's SBH editor. It's basic, but ultimately I did decide that what I churned out of it was better than the hair I'd previously created in Blender - the problem for me was that with standard SBH I couldn't control where the hair was growing without having to save out a separate version of the hair for every single scene that I did. (You can load in new generation maps into the editor, but they're not saved into the scene, and are lost when you reload, which is a huge hassle if you need to use Render Queue or similar).
As such, I had to go through a really quite tedious process of converting it to a UV mapped geometry, and it's not possible to use the OmniHair shader like I'd originally intended.
But yes, one way or another, the standard SBH is missing a lot of features more than just being able to simulate; can't save generation maps into the scene on a hair level, can't apply override maps at the shader level, can't import it without the special tools. So that's a big part of why you'll see hair that doesn't need simulation that's in the dHair format.
Is there a way to make a shortcut icon in the Daz models directories to load PS models?@Lyn_Buchanan - Creating custom actions and putting them into your Favorites, Scripts or other menu is a good way to find frequently needed items. Those menus allow you to create sub menus if desired when you need a bit more organization in them. However, if you have a lot of items that you want to quickly locate, another tool is to use Create a Product from … feature in Daz Studio. When you create a product, you can add items to it from one installed content item or from as many different installed content items as you wish.
1. For example, the first image below is from a wardrobe item in my Poser content library in my Content Library. It came from Renderosity and I manually installed the files in my Poser Library to which Daz Studio is also pointed via the Content Directory Manager.
2. I can right-click on the item’s folder in the left side of the Content Library and select Create a Product from … (second image) to create a new product containing all of the files in the folder.
3. Or I can right-click on individual items (as few or as many as desired; I have selected three in the third image) on the right side of the Content Library and select Create a Product from …to create a new product containing the selected files.
4. A newly created product will appear in Smart Content initially without an image icon; it will show the default ! icon because there is no icon image file yet for new product to use.
5. It will be helpful to sort your Smart Content by Sort by Install Date : Recent First so that the default icon is at the top of the Smart Content pane.
6. You can easily the new product’s icon image from any image that you download or render and save by using the information in the new product’s metadata.
7. Because the files were manually installed and not using the Daz Install Manager (DIM), when the new product is created, it has a dsx file name that begins with LOCAL_USER followed by whatever you named the new product. Name the image file that you wish to use as a product icon in Smart Content by using everything from LOCAL_USER up to but not including .dsx. End the image filename with .jpg to create a JPG file if it is not already a JPG file.
8. Move the image file to your Runtime/Support folder in your Daz Studio content library. In Smart Content, refresh the listing (right click on All Products and click Refresh) for the icon to be shown.
Let's appreciate/discuss today's new releases - ongoing threadMatt_Castle said:
I'd be content if all the standard SBH was missing was the dForce (although it would be limiting from a perspective of draping and posing long hair), but when it's also missing a load of the mapping parameters, converting it to full dHair makes a lot of sense. (Certainly more practical than converting it to geometry, but I didn't have a choice about that, Daz don't let us mortals have the dHair tools).
I would argue that the most important thing missing from DS's SBH tool is the ability to import your own curves. There are all kinds of tools in other programs for creating hair, but as I understand it, only a PA would be able to take hair made in another program and convert it to SBH inside DS.
Latest version of Carrara SDK on DAZ site?Interesting, I asked following question while talking to copilot on bing and here is the answer:
What are the benefits of using Carrara 3D SDK?
Certainly! The Carrara 3D SDK offers several benefits for developers and creators who want to extend the capabilities of the Carrara 3D software:
Custom Plugin Development:
- With the Carrara 3D SDK, you can create custom plugins tailored to your specific needs.
- These plugins can enhance existing features, automate tasks, or introduce entirely new functionality to Carrara.
- Whether you’re building tools for modeling, animation, rendering, or other aspects of 3D content creation, the SDK provides the framework to do so.
Integration with Carrara Workflow:
- By using the SDK, you can seamlessly integrate your custom tools and extensions into the Carrara workflow.
- This means that your plugins become part of the user interface, allowing artists and designers to access them directly within the software.
- Integration ensures a cohesive experience for users who rely on Carrara for their 3D projects.
Extendable Features:
- Carrara’s core features are powerful, but the SDK allows you to take them further.
- You can extend existing tools, modify behavior, or create entirely new panels and dialogs.
- Whether you’re adding import/export options, enhancing the rendering engine, or creating specialized shaders, the SDK gives you the flexibility to innovate.
Community Contributions:
- The Carrara community benefits from the creativity of developers who contribute to the ecosystem.
- By building and sharing plugins, you enrich the software for everyone.
- Collaborating with other Carrara enthusiasts fosters a supportive environment where ideas flow freely.
Personalized Workflows:
- The SDK empowers you to tailor Carrara to your unique workflow.
- If you have specific requirements or repetitive tasks, custom plugins can streamline your processes.
- Whether you’re an animator, game developer, or architect, personalized tools enhance productivity.
Learning and Skill Development:
- Working with the Carrara 3D SDK provides an opportunity to learn about software development, APIs, and 3D graphics.
- It’s a chance to hone your programming skills and gain practical experience.
- As you create and refine plugins, you’ll deepen your understanding of both Carrara and software architecture.
Remember that while the Carrara 3D SDK opens up exciting possibilities, it’s essential to adhere to licensing terms and respect intellectual property rights. Happy coding and 3D modeling!
Blender to DAZ or CarraraImporting materials from blender to daz studio would be impossible, unless we limit it to the principled shader. For the rig it's the same we could only import basic bones, eventually. There was the exporter by Millighost doing this but I don't know if it is up to date or maintained anymore.
Another option is to use poser to export the cr2: blender > fbx > poser pro > cr2 > daz studio.
Daz Favorites to Diffiomorphic import.You mark the favorites in daz studio, then export as usual, then in blender with easy import select the "daz favorites" option. Simple as that.
This should be in the blender discussion though.
Daz Favorites to Diffiomorphic import.Trying to figure out the Diffiomorphic import favorites and it goes somewhere looking for something.Checked all over Daz interface looking for a save favorites (marking the heart) but could find nothing. Is this what diffio is looking for? and how do I find where to save what diffio wants?
Thanks.
[SOLVED] Eyes morph - Morph Loader - Scaling is right but it moves wronglyThat sounds like a scaling mis-match between export and import, or as if there was a morph applied to the exported geometry and not reversed out of the imported morph (the reverse deformations option, assuming the morph was still applied on import).
daz to Blender bridge issue with exportingI have installed the Daz to Blender bridge add on and it used to work fine. But now I am having some variation of this error message whenever I try to import a model animation in Blender:
If anyone has an idea why this is the case please let me know :)))
