Daz 4.9 beta IRay performance
2»
  • That is odd because I'm pretty sure I did a test render of Starship Vampire in Iray when I first got it.  I didn't have any problems with it that I can remember.  I'll have to go check the .duf file and see if it was 3Delight or Iray, but since I hardly ever render in 3Delight, I'm pretty sure it was Iray.  I don't have the other one, yet.  It is in the wishlist, though.  I'll have to make a note of possible problems with 4.8 in the comments so I'll remember.
  • Oso3DOso3D Posts: 15,095
    Dystopian worker drones would crash if you converted them to Iray and set Metallicity above 0. AT 0 was fine... anything else? BYE BYE DAZ
    Given one of my main characters in my webcomic is a Dystopian Worker Drone, this was annoying (I just ended up using a glossier material for a while. Of course, now I've converted over to PWToon/3DL for my comic, but hey)
  • Ah, they are in the wishlist, too, so I don't have them.  Another note to make, I guess.
    edited January 2016
    KA1 said:
    Exactly what was fixed in 4.9 for Iray?  I haven't had any problems with any of my renders using 4.8 so won't be upgrading for awhile, but I am curious as to what the bugs in 4.8 were that 4.9 apparently fixes.
    edit: other than memory that is and that was a hardware problem (not enough) and a Windows problem (memory limitation).  Not any problems with 4.8 specifically
    There were certain objects that would crash if you tried to render - I was unable to do any renders with either Starship Vampire or SciFi Tactical Stronghold Room (or any objects from it!) until I caved and got the 4.9 Beta as I needed to use those sets/ships. Not sure how wide it went there were other objects/figures that crashed it as well.
    There were a few, but I don't think there was ever a comprehensive list of what caused problems...
    Post edited by mjc1016 on
  • So, I found my .duf test file of the Starship Vampire and, yes, I can render it in Iray.  I can't get any lighting to make it look good, yet, but I don't crash when I try to render in Iray.  I have no idea why I can render it in Iray and others can't.  I can't test the other items to see if they cause a problem on my system because I don't have those.
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    For speed, 4.9 is supposed to be faster, according to NVIDIA, but most of the faster gets eaten by the SSS fix in 4.9 in typical Daz Studio renders.
  • HavosHavos Posts: 5,611
    I also can render Starship Vampire in DS 4.8 without problem. This is with the default (ie 3DL) shaders, though after applying the iRay Uber to all surfaces it also renders just fine. Maybe it was certain material settings that caused it to crash, or it crashed only on particularly gpu cards.
