New DIM authentication
jbowler
I can see several problems with this new complexity. Authenticating via a browser means I need to have a browser installed on a machine where I run DIM and I have to run the browser to get the authentication token; given the enormous bloated size of browsers that might be a problem; DIM takes 116MByte of RAM on my current Windows 11 machine, Microsoft Edge uses 600MByte. I checked Edge because I never use it; Google's Chrome, which is what I do use, is currently sitting on almost 3GByte of RAM and even DuckDuckGo (which I use for PDFs) sits on almost 900MByte.
**All** browsers, without exception, are massive bloatware.
It may be better security for Tati, who have the SWEs to maintain it, but for me it's just moved a password in %AppData% (one I certainly know the location of) to an unspecified set of information in (in my case) Google.
I think we are learning, perhaps very gradually, that security through complexity does not work. DIM with a locally stored password was fine for me, though an option not to save it would be an improvement. Anything that involves a browser supposedly for security is not.
You don't have to hve the browser open while using DIM, or even on future occasions while logging in I think (not soemthing I hae thoroughly tested). This applies to DS too (which is why I am leaving the thread in Daz Studio Discussion).
The first part, yes, the second not so much.
If you untick "Remember me" the next time you open DIM, it will open a browser and you'll need to log in there.
If you're already logged into your daz3d account, it'll open the browser, and depending on security settings, either just finish opening DIM or require a prompt to be accepted.
There is an issue for those of us that are on Administrator accounts(this is the actual admin account, not just a user account with admin privelages), the token can't be processed, and will throw the "Program cannot be run as Administrator" error.
The only way i'm aware of to get around this is to go into a user account and login in. As long as "remember me" is ticked, DIM will open normally in the Administrator account when "Run as different user" is used.
If anybody is aware of a different way, i'll gladly test it.
