grass brighter?
cosmicdawnseries
I've checked all lights and positions, but the grass is lighter in frame 35 than 30. Does anyone know why?
cosmicdawnseries
Sorry, here's pictures
As a total guess, I'd say you moved something in the scene with an errant keystroke change the position of something. I have no idea how we can diagnose this further without a lot more scene details.
Assuming you've checks none of the light sources are altered, load the two pages into DS. You now have a bunch of "Asset" "Asset (2)" nodes in the scene hierarchy. Select each pair one at a time. In the parameters table check "Currently used". Every parameter row should have a little (2) at the front indicating that 2 of the selected assets have the same value. Go through them all looking for places where the (2) is missing since that means the two assets differ for that parameter.
Good Luck.
Thank you for the reply. I will try it
Thanks again :)
That is odd as nothing else in the render is changing, so the suspicion would be that some property is inadvertently keyed (animated). Select the prop(s) for the grass and look in the Timeline pane to see if there are any key markers after frame 0 - assuming it isn't deliberately animating in some way.
It's very weird. I did a render before it, and it was fine; the only difference was that the camera was still. I went back to that scene and changed the animation to the newer one, but the grass does the same, so I can't think it's the grass itself- something to do with the camera
First and last frame of the last scene I did
So I kept the camera still, and it's now no flashing. I'm using headlamp light 1.0; I'm thinking it could be light reflecting off the grass. But either way, I think I found the problem. Thanks for your help
