Ragdoll stitches
Ragdoll Stitches | Daz 3D
When I add stitches, whatever bodypart is affected disapears. T(his happens with or without geoshell and the reset buttons do not have any effect.
  • GordigGordig Posts: 10,845
    Just to be clear, you're applying them to the geoshell itself, not just to the figure with a geoshell on it?
  • dennisgray41dennisgray41 Posts: 1,016
    Yes, that was the problem. I am not familiar with geoshells.
    My only problem now is that if I load a stitch in one area such as the face, it erases any other item in that location. The promo led me to believe that all of the items could be used at the same time
    457 x 561 - 244K
    457 x 561 - 245K
    2000 x 2600 - 5M
  • felisfelis Posts: 6,652
    If it doesn't have combo options, you can do it in different ways.
    You can use more geoshells, for each area, but that would use more geometry.
    But you can load them onto different geoshells, and the copy the relevant surface from the outer geoshells onto the inner. And when that done you can delete the outer geoshells.
