Dforce - Error initializing opencl kernels
Hi everyone,
I'm currently using a AMD 5700xt. I recently updated to the latest GPU drivers and it seems AMD has changed the GPU ID to read "GFX1010 :xnack". When dforce tries to compile the kernels needed for simulation I'm meet with the Error Initializing OpenCL kernels". Any fellow AMD users found a solution to this other than downgrading the drivers? I've tried several of the latest drivers after 21.3.2 and dforce still has the same issue.
Thanks guys!
  • I am having the exact same issue.  I would love to hear a response.   With the amount of money I put throught the Daz store, I would expect at least a little customer service, or at least the resources to find my own answers.
  • Bobeagle77Bobeagle77 Posts: 164
    edited December 2021
    Same problem. I wanted to start using dforce but it seem broken on my computer. On the simulation settings. I checked the "advanced" tab. I only have one option it says -OpenCl Device: AMD Accelerated Parallel Processing gfx1031. I run dforce simulation in about 5-6 sec. I get "Error Initializing OpenCL kernels". Any help will be appreciated. Here are my computer specs, everything is uptodate:
    Windows 10 (64 bit) Primary Display Resolution: 3840 x 2160
    AMD Custom Ryzen 7 1700 Eight-Core Processor At 3.4Ghz
    Radeon RX 6700 XT Graphics 12Gb Memory: RAM 24Gb
    3668 x 2064 - 489K
    3668 x 2064 - 476K
    Post edited by Bobeagle77 on
  • 1jayree1jayree Posts: 3
    I have somewhat the same problem.
    I have a female character sitting on a chair. I need her dress to not poke through the chair.
    I'm trying the dForce simulator but for some reason I'm getting an error message.
    error inilizing CL kernals.
    any advice would be greatly appreciated.
    1062 x 595 - 170K
    1378 x 775 - 310K
    1358 x 771 - 304K
  • Hi Perttia that doesn't work for me. :(
  • ctkassemctkassem Posts: 2
    I'm rezzing this because I found what worked for me.  GPU=7900XTX and CPU=9800x3d.
    After trying multiple solutions including a regedit, the following steps (in order) worked, so in DAZ I now have 3 more OpenCL Device options and the "OpenCLOn12 AMD Radeon 7900 XTX" loads the kernels and dForce functions.
    I uninstalled "OpenCL™, OpenGL®, and Vulkan® Compatibility Pack" and used DDU to uninstall my GPU driver and Adrenaline software.
    Reboot.
    First, installed OpenCL™, OpenGL®, and Vulkan® Compatibility Pack (Run as Administrator).
    Reboot.
    Second, installed Adrenaline and GPU drivers.
    Reboot.
    Open DAZ3, change the OpenCL Device to "OpenCLOn12 AMD Radeon 7900 XTX"
    Click "Simulate."
    Microsoft OpenCL Compatability Pack:  https://apps.microsoft.com/detail/9nqpsl29bfff?hl=en-us&gl=us
    AMD Adrenaline Download:  https://www.amd.com/en/support/download/drivers.html
