dForce (seriously?) Gentle Curly Hair for Genesis 9
greywolf
Hi, I'm posting this here because I can't post in the PA thread (I'm not a PA, so I guess that's no surprise but a banner declaring this before I start a post would be helpful. ANYway)...
So https://www.daz3d.com/dforce-gentle-curly-hair-for-genesis-9, on Eden for Genesis 9.
It says it's dForce, but the hair absolutely does not move when run thru a simulation -- the back part hovers away from the back of the character and will not move. I found the dForce weight node but it has no effect whatsoever on the hair. If I try to rotate the hair at the 'Neck 2' node, it peels the hair off the head. Same as if I rotate it at the 'Head' node.
What am I doing wrong? It's a very pretty hairstyle, and I like it, more or less, but I feel like 'dForce' in this case was a serious misrepresentation.
There are a lot of different meanings for dForce and it appears that this one does not have movement. I don't have the hair to check. You might be able to use some of the dials to make it work.
To keep the shape of this polygonal hair, the vendor painted less weight on the hair's dForce modifier weight node, you can add more weight to the lower part of the hair with Node Weight Brush tool. Then it'll drape ~~
@crosswind = Thank you; I would not have thought of this.
