Wardrobe Helper (Commercial)
Hi everyone! This script helps you create your favorite outfit sets from your library and easily transfer them to other saved scenes. If you find a bug please let me know. Thank you
Interesting ~ So it also works for Smart Props, right?
I looked at this product in the shop this morning: https://www.daz3d.com/wardrobe-helper
I don't really understand what it does, what problem it solves, or what advantage it has over a wearables preset or a scene subset.
I plan make better save function for props(sword, knife, smartphones props etc) in an upcoming update for this script. Meanwhile, experimental "Find items method" to search for all elements with props inside character bones does work not correctly while load to character.
Well, Smart Props are not only limited to weapons, consumer electronics...., hats, caps, glasses, collars, jewellery (earrings, bracelets, piercings, etc.), yada, yada... are all commonly-seen wearable accessories. When saving wearable presets, most of the time we need them all.
Thanks!
Personally, I'd like to suggest rename it to Wearables Helper.
Anything the script finds without the “Find items method” option enabled - all, will work at moment, but in a future update I plan to improve this option to transfer items correctly, it takes more time to fine tune it.
Okay, great !
Any chance of attaching the PDF to this thread, so we can read more about it?
I have made improvements, now all wearables and props are load and save correctly. I will submit a request to update script after debugging it
I'll look into that question, whether it's possible.
I'm absolutely excited about the wardrope helper!
It saves so much time as I only have to dress a character once, adjust the clothing, save a wardrobe and can load it later on different characters with all adjustments dialed in, and it takes also custom geometry groups - I love it!
If you plan an update, here are some ideas for additions:
- At least for shoes, it would be great, it it would be possible to optionally save/load also the feet pose
- Loading just the subset of a wardrobe would be nice
- It would be cool if directories in the options could be modified (for backup)
- An options to add the wardrobe helper to the tools bar would also be great!
Thanks again for this very helpfull script!
Happy New Year
Hi, thanks, glad you like it. These features you described are already in the update
Sounds great! When will the update be available?
Thank you for the very useful "Wardlobe Helper". It has saved me a great deal of time.
There are no issues with Genesis 9, but I’ve encountered a minor problem in Genesis8 or Genesis3.
For example, if the Genesis 8 figure is moved -50 on the X-axis, and clothing is loaded using Wardrobe Helper, the clothing gets loaded with an X-axis value of 50. This issue does not occur with Genesis 9.
Would it be possible to fix it?
@Jakamoto, @RedStote, Hi, thank you for noticing this bug. I've already reworked the script and everything will be fine in the next update. Possibly with daz 2025 release or earlier
@Envy, just a shout-out and huge thanks for creating Wardrobe Helper—it’s such a game-changer in my workflow. Makes organizing and building looks so much smoother. Seriously appreciate the work you’ve put into it.
Curves&Codes, thanks. I'm glad you like it.
Hello, I keep getting the following error:
Is this product currently supported by daz studio 6? Thank you!
Please attach the image, if you just paste it in it won't show in the post.
It's a script, not a plug-in, so it may or may not work in DS 6. What were you trying to do when you got that error?
Hi @collin1216, The update is already being tested. DS6 support will be added. Thanks
Thank you @Richard Haseltine and @Enve for reaching out and giving me some information, I just try and run Wardrobe Helper in DS6 and I get the attached, (really hoping this shows up in attachments). Glad to hear it's being tested and updated for DS6, thanks!
I can reliably crash DAZ(and lose all my custom scripts and everything about my layout and menus) by using Wardrobe Helper.
Just rename an outfit set. I'd say this has happened six or seven times, now. Glad I didn't lose much on DAZ 6 scripts.
Wardrobe helper just doesn't work at all on DAZ 4.24. Trying to save or apply any outfit on the Wardrobe Helper for DAZ 4.24 does not work at all. It "runs" but does nothing.
@Somnovox hi. Which version helper? Last version 103. Have you updated?
