Adding to Cart…
Testing a new RawArt character
https://www.daz3d.com/raw-deals-nyxii--robot-girl-for-genesis-9
with
https://www.daz3d.com/iray-window-lights
Also used
https://www.daz3d.com/xi-sushi-restaurant
Messing around with https://www.daz3d.com/speed-instancer
on https://www.daz3d.com/polish-dark-retro-classroom
Exploring more, newly released:
https://www.daz3d.com/dforce-venus-hair-for-genesis-9
Great job. Lokks totally relistic.
Did you apply DForce?
Thanks. He is on my wishlist. It is good to see some renders since Daz Construction on the gallery seems to be handled by the highway dept.
What is "duplicate formula error" ?
Sorry, I got impatient and pressed post comment 3 times. Is there any way to delete a post made in error?
Th'isd is the one that brought me here. Just gone through the whole thread. Unfortunately, many of thje older posts, imcluding this one, the images don't work. Still great job. I was just thinking the other day that if Daz won't fix the gallery, maybe people could have a thread where they show renders made with new releases.
Thanks a lot for the comments.
Please check one of the many threads about duplicate formula found
https://www.daz3d.com/forums/discussion/609436/duplicate-formula-found-genesis-9/p1
Such bad made characters causes error messages pop out during using such items in Daz Studio.
Sometimes the solution is published, but not always.
From the search on Google - longer explanation:
The "Duplicate formulas found in files" error in Daz Studio happens
when two different morphs, assets, or DSF files use the same property name or ID,
or when a property has conflicting links.
Causes
• Conflicting Content / Third-Party Assets:
Two different creators (or old vs. new versions of a character/bundle)
used the same name for a morph or property.
• Mixed Install Methods:
Installing the same product through both Daz Install Manager (DIM)
and Daz Connect (or manual zip extraction).
• Repeated ERC Freeze:
Running ERC Freeze twice on a morph within the same asset file
can duplicate internal coding blocks.
How to Fix or Troubleshoot
1. Check the Log File:
To see which specific files or paths are clashing,
go to the top menu in Daz Studio and select:
• Help > Troubleshooting > View Log File.
2. Locate and Clean Up Duplicates:
• Identify the conflicting asset or character mentioned in the log.
• Remove duplicate manual installs or old zip/rar extractions from your content directory,
or reinstall the affected product cleanly.
• If a third-party content pack or commercial product has the overlap
(such as duplicate naming from different vendors),
you may need to wait for an update from the creator
or temporarily uninstall the clashing item.
3. Ignore (if harmless):
If the figure loads normally and you do not experience performance drops
or broken materials, clicking through the prompt is sometimes the only short-term workaround
until the offending file is updated or removed.
You can read community discussions and troubleshooting steps on the Daz 3D Forums.
More threads on the topic "duplicate formulas found error":
https://www.daz3d.com/forums/discussion/701346/duplicate-formula-found
https://www.daz3d.com/forums/discussion/599506/duplicate-formulas-found-in-files/p1
https://www.daz3d.com/forums/discussion/641521/content-library-repair-after-duplicate-formulas-found-error
Used https://www.daz3d.com/dforce-cb-mollie-mae-outfit-for-genesis-8-females-bundle
on https://www.daz3d.com/lynelle-for-genesis-8-female-and-hollywood-mansion
Render DS6
Edited with MatineeFX https://www.daz3d.com/matineefx
Used preset Three-Strip Hollywood
Experiments with https://www.daz3d.com/fire-font--volumetric-flame-text-for-daz-studio
and editing it in MatineeFX https://www.daz3d.com/matineefx
Original:
Three-Strip Hollywood preset in MatineeFX:
UltraScenery 2 render in DS4
Applied Heavy Fog in MatineeFX
I like the way you exercise the products you buy and show off the results here in the forum.
Thanks a lot, @barbult
I am trying to share my results, especially for the new products, that I like.
Exploring Depth Of Field feature in MatineeFX https://www.daz3d.com/matineefx
Possibility to choose focus point without the need to render again is awesome.
Used: https://www.daz3d.com/outer-space-laboratory
and https://www.daz3d.com/squat-bot for the focus point.
Original:
With DOF applied:
Looks even better with "Auto Level Emission" applied.
Wth added flare.
Another edit with MatineeFX https://www.daz3d.com/matineefx of
https://www.daz3d.com/mb-liwia-for-genesis-9-feminine
https://www.daz3d.com/dforce-mb-cheerleading-uniform-for-genesis-9-feminine
https://www.daz3d.com/xi-campsite
Pose from https://www.daz3d.com/camping-poses-for-genesis-9-and-xi-campsite
Original:
DOF and Halation (Auto Level Emission) added in MatineeFX
MatineeFX editing of https://www.daz3d.com/marsupial-lion-by-am
