Tropical Plants for Daz Studio and Iray.
Martinjfrost
Tropical Plants for Daz Studio and Iray is a new bundle of useful greenery for your Daz studio scenes. The foliage is the most realistic yet, with translucency and back lighting to leaves that gives you an extra sense of depth and a very nateral look.
Martin,
Very impressive, indeed. All this and Iray materials as well! This has just gone on this week's shopping list.
Cheers,
Alex.
Only Iray is mentioned in the description. Does that mean it will not work with 3Delight?
Iray will always work in 3DL and vice versa. You will need to change the shaders to the default (true either way). DS should auto-convert, but that sometimes needs tweaking.
Bought and installed. Coming soon: bear cubs in the woods with extra tropical plants.
Cheers,
Alex.
May I add a request here? I am still in need for an Iray plant shader set. Converting excisting 3dlight plant shaders to Iray plant shaders.
@Masterstroke
Why not get Martin's package and try using the shaders on your existing 3DL plants?
tried that and it was a lot of fiddeling. I don't know how to avoid overwriting existing textures.
Masterstroke Hold CTRL down while applying shaders and choose to "Ignore" replacing existing textures
A render using some of Martin's tropical plants.
Cheers,
Alex.
Ooooh !!! cool, thank you. :)
Quoted myself :D
Thank you, finally in the store. http://www.daz3d.com/nature-shaders
Damn, thats cool; just added it to wishlist; I've a use for it no a project next year.
