Stop poses from overriding my pose locks.
Some pose makers have found a way to override my locked pose positions, for example, the feet - locked for high heel wearing.
How do these pose makes do this?
How can I override their overrides?
  • ElorElor Posts: 4,187
    I would check if they are using Pose controls because after a quick test, locking transforms on a bone will not prevent pose controls to change the locked parameters.
  • lukon100lukon100 Posts: 855
    Thanks, Elor. That makes sense. I have already noticed that pose controls override bone locks. So I guess that certain vendors incorporate pose control settings into their pose presets.
    Is there a way to convert such pose-control using prests into versions of those presets that don't use pose controls? Like, If I pose the figure and manually override the pose controls in the pose preset, and then save that as a pose preset, does my new pose preset get rid of the calls to any pose controls?
  • Yes, as long as you include the proeprties in the options dialogue (assuming you make choices rather than saving every setting).
  • crosswindcrosswind Posts: 10,341
    edited September 27
    In other words, Locking bones Transforms cannot prevent them from being triggered by ERC linked controllers ~ That is not set by pose vendors but just the way that DS works...
    So a better way to "override the overrides" is to : in addition to locking the bones, also make them "override any controllers" by clicking the chain icon beside the lock icon ~
    (Vendors or you can change Pose Controls to pure transforms by using Bake to Transforms... but that'll take more time. )
    Edit: You also can use a Daz Script to do it on a selected Bone ~~ Below script sets Override as On.. with the selected Bone as well as its children bone ~
    // DAZ Studio version 4.24.0.4 filetype DAZ Script
    (function(){
        var oHelper = new DzSceneHelper();
        var aSelected = Scene.getSelectedNodeList();
        if(!aSelected || aSelected.length == 0){
            MessageBox.information("No nodes selected.","Override Controllers","");
            return;
        var aNodes = [];
        for(var i = 0; i < aSelected.length; i++){
            var oNode = aSelected[i];
            if(!oNode)continue;
            if(aNodes.indexOf(oNode) == -1)aNodes.push(oNode);
            var aChildren = oNode.getNodeChildren(true);
            for(var j = 0; j < aChildren.length; j++){
                if(aChildren[j] && aNodes.indexOf(aChildren[j]) == -1)aNodes.push(aChildren[j]);
        var nCount = 0;
        for(var n = 0; n < aNodes.length; n++){
            var aProps = oHelper.getPropertiesOnNode(aNodes[n],false);
            for(var p = 0; p < aProps.length; p++){
                var oProp = aProps[p];
                if(!oHelper.isTransformProperty(oProp) || oProp.isHidden())continue;
                oProp.setOverrideControllers(true);
                nCount++;
        MessageBox.information("Override Controllers >> ON\n\nVisible Transforms: " + nCount,"Set Override Controllers","");
    571 x 260 - 44K
    zip
    zip
    Scripts - Override Controllers.zip
    1K
    Post edited by crosswind on
