Points and Textures in UV View (solved)
Cayman StudiosCayman Studios Posts: 1,141
edited December 2015 in Hexagon Discussion
Is there any way to manipulate the points in UV View and also retain the underlying texture image?  Whenever I click on a point to move it the texture image disappears.
Post edited by Cayman Studios on
  • Problem solved.  The required Material had to be set for the main object, not just for the Shading Domain.  It was only because I had this working in another file that I persisted with looking for a solution.  Hexagon is so damned flakey!  I never know if I am making a mistake, or the feature does not exist, or simply that Hexagon is fully RAMmed up and is now too tired and needs some sleep.
    I Know how it feels :)
    Glad to hear you solved the UV problem.
