Points and Textures in UV View (solved)
Cayman Studios
Is there any way to manipulate the points in UV View and also retain the underlying texture image? Whenever I click on a point to move it the texture image disappears.
Post edited by Cayman Studios on
Problem solved. The required Material had to be set for the main object, not just for the Shading Domain. It was only because I had this working in another file that I persisted with looking for a solution. Hexagon is so damned flakey! I never know if I am making a mistake, or the feature does not exist, or simply that Hexagon is fully RAMmed up and is now too tired and needs some sleep.
I Know how it feels :)
Glad to hear you solved the UV problem.
