CBS issue
cassandra
Hi,
I am having an odd problem with G9. Whenever I bend her leg, this is what I get:
I have reinstalled G9, cleared cache - and the issue is still there.
Any tips on how to solve this?
Issue is solved - removed EVERYTHING and reinstalled
Almost certainly a corrective morph kicking in when it wasn't needed (probably missing a multipler with the shape it belongs to). If you had checked hidden properties (Parameters pane option menu>Preferences) with a minimum pose applied you could have found it by zeroing each until it went away, then checked to see if the product had an update and reported it as a possible bug if not.
