Identify Background Environment
nightwolf1982
in The Commons
https://gcdn.daz3d.com/p/8624/i/hot-dress-unimesh-fits-large.jpg
Does anyone recognize the room from this promo?
it could be https://www.daz3d.com/harwood-house going by the window
possibly kitbashed with other furniture and props, cannot check right now but that TV not in listed props
I added the image to help others to see easier and stay on the page
Nice suggestion, WendyLuvsCatz, but the windows and the trim around them don't match up.
...I did an exhaustive search both here and at the "other" two stores. and came close but nor a match. It looks damn familiar though. Of course the store search here also leaves a lot to be desired.
I tried to find a match through Google Lens by isolating a part of the image without including the figure was but it was too small.to produce an accurate match.
As the dress is ca. 2013, the set must be from around then or earlier and possibly may have been discontinued. Or teh room could be a kitbash using Collective 3Ds "Create A Room" elements but I don't recall that particular treatment on any of the window frame components unless they were further kitbashed.
As I mentioned it looks awfully familiar so I may actually have this set in my Daz content library or Poser runtime but it's 02:20 here and I need to turn in.
The 'Elite textures Lana', listed in additional products for the 'Hot dress Fits' is pretty old. I bought it in 2008, not sure if it was a new item then. But it might have been an old item when it was used in the advert.
The TV is also from that product. It's from 2007
And it's no longer available, thanks anyway, background!
..ah, when I mentioned 2013 that was after I clicked on the image and it took me to the Unimesh Fits which were released then (based the ReadMe file for the product)
For the setting, probably the best solution would be to use Collective 3D's Room Creator elements and add a few touches to get the same look. As I understand they are still on sale. I find those kits along with various texture content sets to be extremely useful. The next best thing to trying to model it yourself.
Sorry to ressurect an old post, but does anyone know what headset might have been used, or one that looks similar?
I have no idea. From way before I started with Daz Studio.
But would this be of interest? I modelled a quick headset, used G8F as refence, but it is a prop, so would assume it could be used on all generations.
That's a good looking headset. All of the ones I've found so far have only had the boom mic on the enclosed ear type.
Looks good, but I found one in the old Ninja Setsuko set I have.
There are a couple of microphones in https://www.daz3d.com/k-pow-props-and-accessories-for-genesis-8
@Garrett_3d I have attached a zip with the headset.
There is a prop and a wearable for G8F, both in People/G8F/Accessories folder.
I haven't tested it, but I think it should work.
Awesome, thank you. I shall have a play with it shortly and post results up.
It's worked out perfect for a character in my next visual novel. Many thanks.
You're welcome.
