Gen 9 pelvic bulge in outfits
In a lot of dresses and genesis 8 converted outfits, there is this nasty looking bulge around pelvic region in genesis 9 figures. I noticed it was even in some daz official promos, so even they aren't much bothered by it. Any one know how to solve this ?
  • ElorElor Posts: 4,227
    edited September 19
    I don't have any of them so I don't know how good it is, but Sickleyield is selling tools to deal with that triangle shape:
    The other way to deal with the problem is to create, for the clothes, a morph that will replace the one generated by auto-follow (which can be done by using Blender, Zbrush or other softwares like that). An example, on a simple dress:
    On the left, the dress worn by a character for which there is no such morph was created (smoothing is disabled to show the problem more), on the right, a character with a morph created.
    Jay Versluis has a couple of videos on the subject:
    It's also possible to create such morph by using the Smoothing Modifier in Daz Studio, setting it to very high values (@crosswind has some explanations somewhere on the subject), but the downside is that you'll lose details you could retain creating it yourself, so on some clothes it may not be an option.
    765 x 995 - 297K
    Post edited by Elor on
  • Are you saying that I create a morph for each of my outfits and lose the deails by smoothing out the bulge. I'm sorry but thats not a solution I'm looking for.
    Don't worry, none of Elor's suggestions actually solve the problem, at best they just hide it, as long as you don't bend the legs, or try to run a dforce sim on it.
    The real solution, is worse.
     You have to correct the rigging and weight mapping to better match the original figure.
    Unfrotunately autofit can screwup the mesh so bad, you may need to take it into a modeler program to fix the squashed polys.
    In most cases, you might as well start from scratch with the amount of time it's going to take to fix.
    I've attached a couple images to give a better idea of what's going on here.
    997 x 995 - 257K
    993 x 1003 - 443K
  • crosswindcrosswind Posts: 10,347
    edited September 19
    That's a common issue of weight projection when Auto-Fitting clothing on G9 which has a different skeleton / weights from previous Genesis generations.
    So, yes, to remove that triangle bulge, you have to fix the clothing shape after Auto-Fit is done... but you don't have to create a morph, just use the function: Figure > Geometry > Update Base Geometry.... It'll only update the garment's vertex postions without creating any morphs.
    Besides, if you go for the way of using Smoothing Modifier, you also can avoid losing details by using : Morph Loader Pro > Attenuate By option, i.e. to just update the bulge area (on which you create a Selection Set firstly...) with the smoothed garment object.
    If with Blender or Premier Tier's Geometry Sculptor or Sculpt Tool plugin, the process of fixing will be much simpler ~ ~  The ways that Elor suggested would work ~
    The screenshots show the result that I fixed an auto-fitted skirt by using Smoothing Modifier + Update Base Geometry, with no morph created, almost all details preserved.
    Edit: Finally, optimizing weight maps / corrective morphs might be needed... dForce ready clothing may save you some time depending how well it works on the garments.
    2560 x 1392 - 2M
    2560 x 1392 - 2M
    Post edited by crosswind on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,748
    as long as you have it fitted to the base figure in the zero pose at base resolution, sending to Hexagon and using the smoothing brush there and sending back to DAZ studio as a morph is also an option
    edited September 21
    You'll lose details if the morph is created within Daz Studio using a Smoothing modifier (if you don't follow another crosswind's trick I didn't know about).
    If you're using an external modeller, it will depend on how you're creating the morph and the starting point used:
    • if you start from the result of autofollow and use the smoothing brush to fix the problem, you'll lose details in the areas smoothed, but keep them elsewhere.
    • if you start from the base shape of a piece of clothing, and use, let's say, Blender's Edit mode tools, you will retain more details (but it will likely took you longer to create the morph because you'll have to do the work done by autofollow).
    Then you can also try the Sickleyield's products I linked: they are advertised as tools to solve that problem.
    You can also try to use timeline simulations.
    With a native dress, you put your character in the base shape (so Genesis 9 Base for G9, Genesis 8 Female for G8F and so on) and default pose at the first frame, then, you build a 45 frames timeline as follow:
    • Frame=15, character is in default pose and it's final shape.
    • Frame=30, character is in the final pose and final shape.
    The last 15 frames will allow the simulation to stabilize.
    With an autofitted dress, as long as every part of the dress is simulated, you can bypass autofit completly by having the dress fitted to an almost invisible to simulation figure of the correct generation (so G8F for a G8F dress, G9 for a G9 dress, etc) and building a timeline following the same principle as the first case except you have to manage two figures.
    Exemple of using a Genesis 9 pajama on G8F in on of my render, Morning routine (with basic explanations, I gave more in one or two forums messages but I don't have the link at hand).
    Hu?
    Using a morph to remove the triangle does work and it won't magically come back after a simulation (I doubt it'll come back after bending the legs even if other problems will likely appears), regardless of the generation of origin of the outfit.
    Same dress after a simulation (on the left, CBS created by autofollow while on the right, I created the CBS from the dress base shape in Blender), with the smoothing modifier disable: the triangle area is less visible on the left (but I would say is still here).
    What's perfectly visible is how the dress drapped around each character's breasts and how the work done to avoid the usual 'vaccum sealed' effect from autofollow was not reversed by the simulation.
    If you prefer an example with autofitted outfit, here's one with a G9 skirt on G8F (less a triangle problem than a problem with the legs pose difference between G9 and G8): the texture deformation (due to the mesh deformation) is still gone after a simulation done with a morph made to fix the problem:
    873 x 997 - 308K
    840 x 840 - 87K
    840 x 840 - 86K
  • garrett_3dgarrett_3d Posts: 1,039
    edited September 21
    I came across this yesterday with a G8 dress (fitted to a G8 character). Fit Control worked like a charm to get rid of it.
    Post edited by garrett_3d on
