Draped Ghosts Breastmorph
https://www.daz3d.com/draped-ghosts
is there a dial or preset to remove the breast shape on those ghosts?
  • jmucchiellojmucchiello Posts: 2,559
    It says on the page they are static props that can't be posed. If they can't be posed, they probably have no morphs either. Short of editing the mesh directly, the answer is probably no.
  • That was my thought too. They are a bit, um, prominent. It almost makes one want to use dForce on a high resolution 2.5x2.5m plane (say 100 facets in each direction) and do a drape over your own character in a 'ghost' position, save the plane as a prop, and then use that. That way your ghost can have the protuberances you want, instead.
    Regards
    Richard
    The point of most "tool" products are to save you time. If you have the time, you can make an apartment, or a bathroom you can park six cars in, or in this case drape a sheet over a character. If the tool isn't exactly what you need, you end up having to do it yourself.
  • I have little time. And even less money...
    Regards,
    Richard
  • FantastArtFantastArt Posts: 427
    Thank you all! Well there are other ghosties in the store. I just want to make sure. Thanks a lot.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,777
    honestly make your own by draping a subdivided plane over a figure as a chair pulls up and it sits over about 60 frames,
    export the cloth at the end as an obj after deleting the figure and chair
    I am betting thats what Dreamlight did
  • I guess it's cold in the netherworld
  • chris-2599934chris-2599934 Posts: 1,987
    edited September 10
    The mesh doesn't look like what you get on a plane primitive:
    It looks like what you get from photogrammetry. Maybe he got an (apparently rather cold) lady to sit under a sheet for him to photograph from multiple angles? Actually, that's what he says in the product description:
    These 3 scary and detailed draped "ghosts" are HD scans of real size people, draped in bright grey cloth
    "Real size people" might mean a dummy rather than, well, real people.
    But yeah, easy enough to make something similar with a plane and dforce.
    Post edited by chris-2599934 on
    or           ...bodies
    stiff ones
  • garrett_3dgarrett_3d Posts: 1,041
    Forgive my ignorance, but couldn't a dForce modifier be added to remove the pokies?
    Just a d-former on each should do the trick.
    Or maybe a Smoothing Modifier.
  • crosswindcrosswind Posts: 10,351
    edited September 11
    I had the breasts shape fixed in Blender.  You can extract the data folder in the attached ZIP to your Daz Library. Load the Prop1 and Prop3 and dial the morphs under Actor/Adjustment (Prop2 has no breasts shape...)
    Edit: Alternative morph makes the crease / fold shape change more on the cloth... pls dial it as needed.
    2018 x 1293 - 864K
    zip
    zip
    Fix Breasts - Draped Ghosts.zip
    430K
    Post edited by crosswind on
    yay to the flat out dead ghosts yes
