Roquet Racoon fur not rendering
Roquet and I are having a disagreement. A fur-disagreement. Roquet is winning, so I come seeking back-up.
Roquet has fur. Roquet's fur is not showing up in preview or when rendered.
I have the universal tool selected. Preview PR hairs is on. If I turn Tessellation on, the hairs turn white.
They don't render, no matter what.
I am out of troubleshooting things to try, so I come requesting more things to try.
Workspace attached.
Thanks in advance!
  • RawArtRawArt Posts: 6,243
    edited August 27
    Tesselation should remain at zero for the shader on the fur to work proper.
    I just loaded the character into a blank scene and rendered....here is how it should look
    1920 x 1050 - 375K
    Post edited by RawArt on
  • May DawneyMay Dawney Posts: 142
    Thank you for your quick response!
    I know it should remain at zero--and I really wish it looked like yours does.
    Any idea how to get it to actually look like that...?
    If all I did was load  it into a blank scene and it loaded fine, I really do not know how to even get it to look like your did.
    You will likely have to send a ticket to daz and explain everything you did as you loaded it in the scene (they have the ability to test it on different systems...I only have my own)
    Appreciated! I dropped it into a new scene after restarting DAZ and it...errr... it got mini hairs...?
    1118 x 657 - 649K
    Make sure you don't have a mesh editing tool like Geometry Editor or mesh grabber (or the Premier member version of Mesh Grabber) selected when you render. It makes dForce strand based hair render incorrectly. Switch to the Node Selection tool or Universal Tool, and hair will render correctly.
