New Year, New Sales Thread: Report Issues Here 4 "Reporting Only"
1…7374767879…92
  • FantastArtFantastArt Posts: 427
    Matt_Castle said:
    NEW-FLASH-3 code is still being advertised in DIM, but does not work (and no, I haven't previously used it).
    same here
  • frank0314frank0314 Posts: 15,115
    I let them know. Thanks for pointing it out
  • JohnMRJohnMR Posts: 11
    edited August 20
    In the end I founded why the code was not working for me.I added only discouned items, less than 10 $, and unfortunately I can't purchase them as free items.
    If I had applied the code to a full , non-discounted item it worked.
    Thank you DAZ3D, but now I can't spend any more money in 3d models.
    Thank you,  to all the people which had responded to my message and had tried to help me.
    Use code GET-ROWDY
    to get $10 off Daz Originals
    Post edited by JohnMR on
  • jmucchiellojmucchiello Posts: 2,485
    Tokens are not working
  • BeulahBeulah Posts: 5
    In what way aren't they working?  Do you have a screenshot of the cart they aren't working on
  • Cris PalominoCris Palomino Posts: 13,034
    In what way are they not working?
  • MickyBeMickyBe Posts: 366
    Same here, tokens indicated as applied on item in cart
    but no discount on price ...
    1416 x 781 - 294K
    Reporting.
    Tokens should be working now.
    Thanks, I confirm it works now.
    Use code GET-ROWDY
    That's odd. I had no trouble using the code, with an item that was discounted to $10. Sorry you couldn't get it to work.
  • Rod Wise DriggoRod Wise Driggo Posts: 2,346
    edited August 22
    PICK-A-FAVE not working with new releases? If so it's not mentioned in the small print.
    Post edited by Rod Wise Driggo on
  • ElorElor Posts: 4,220
    There is no new release in the eligible selection, so why mention the coupon won't work on them?
    https://www.daz3d.com/pick-a-fave#filter_inWishlist=yes&filtered=1
  • vwranglervwrangler Posts: 5,053
    edited August 22
    PICK-A-FAVE isn't working with the items in the eligible selection, either. I've tried several items on that list, and every single one gets "Coupon code not valid". Tried cut-and-paste and typing directly, and neither works. See attached.
    selection options
    cart
    1504 x 536 - 184K
    1470 x 743 - 126K
    Post edited by vwrangler on
  • caravellecaravelle Posts: 2,791
    Same here.
  • KinichKinich Posts: 941
    The code is 'PICK-A-FAV', no 'E', works for me.
  • EboshijaanaEboshijaana Posts: 579
    Not working here, either.
    Are you using PICK-A-FAV or PICK-A-FAVE? The latter is incorrect. Otherwise, it's working on my end.
    PICK-A-FAV worked.
    Ah, OK. I'd have sworn that it said PICK-A-FAVE. But yes, PICK-A-FAV works.Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,854
    I think it did, initially (and no, I did not type that page).
  • barbultbarbult Posts: 27,631
    edited August 23
    laughYour comment made my day!
    Edit: Oops I had to correct and unintentional typo in my response. An intentional type may have even been better, though.
    Post edited by barbult on
  • WandWWandW Posts: 2,907
    What happened to the QuickGrabs??  I had one in my cart, and went to check out and it was $14 instead of $1.99... angry
    QG changes at UTC midnight, 7 hours before Daz midnight in Utah. We don't know why.
    That is indeed odd, because the sales policy page states; "Sales events are based on the Mountain Time Zone."
    I filed a Ticket.
  • CybersoxCybersox Posts: 10,022
    I filed a Ticket.
    That's what it says, but IIRC, it kept constantly changing instead at noon DAZ time... until it switched to changing at UTC midnight.  Draw from that what you will, but as most folks will have had a week to decide whether to purchase any of the FGs, I'd personally rather get it early than half a day late.
  • Cybersox said:
    I filed a Ticket.
    It started changing Sunday UTC midnight to solve a problem where there would be no items from Daz midnight changeover until sometime Monday. This was after weeks of people asking for a fix, so we just shrugged and dealt with it.
    QG isn't the only thing with a weird time. If you have a paid membership, it ends on the last day at whatever time you ordered it, instead of Daz midnight which it did for years.
  • NorthOf45NorthOf45 Posts: 5,917
    Spell check: D-i-s-c-o-u-n-t excludes New Releases and Daz+ items.
    Cybersox said:
    I filed a Ticket.
    This isn't the only place where Midnight Mountain Time isn't always the cutoff time. The Premiere/Plus coupons page lists the next month coupons at UTC midnight on the last day of the prior month. I think it's mostly the web server isn't setup correctly. Because you can still use the prior month coupon in that window between midnights on the last day of the prior month.
    edited August 25
    Edit: from what I now see, it is fixed, thank you :)
    Original message:
    Golden Tickets doesn't seem to add the intended extra discount: the Mousso character only has the 55% base discount and doesn't receive the extra 30% related to owning or buying a Golden Ticket.
    748 x 367 - 38K
    Post edited by Elor on
