Content Catalog - Windows/macOS (Commercial) - Out now
1246
  • CybersoxCybersox Posts: 9,960
    edited August 19
    barbult said:
    Cybersox said:
    davidwski_16294691f0 said:
    How long does this Content Catalog app take to scan say '1000' zip files for display in the output? That would be my main concern. I would think a large folder could easily take multiple hours to scan.
    That said, I can think of one add-on that would make this an even more powerful product... automatic formatting to DIM ready files or a similar automatic installing system, though that's probably a pipe-dream.
    DoctorJellybean already has another product in the Daz Store to do that. It is Content Package Assist. It's several years old, but still works great.
    Content Package Assist won't do a batch process of a folder full of files, and one has to manually feed the skus into tabs*, that's why I suggested a mash-up.  And yes, I bought Content Pakage Assist back when it first came out and, after fiddling with it for a bit and seeing how long it took to format each one, looked at all of the the products I've bought from the other stores... currently over Renderosity alone, which at the time was probably over 10,000 products given that it's been ten years and my Rendo count is now over 17,000 products, then looked at all of the other products I had from the other stores, plus the huge piles of freebie items from variously places and said "oh, the heck with this, I'll wait to see if they make an update that doesn't keep me chained to the keyboard for six months doing data entry."  With this coming out, it seemed like the time to mention that possibility.
    * or, at least that's the way I remember it from ten years ago. I had more hair on my head, less coming out of my nose, and more brain cells devoted to memory storage back then.
    Post edited by Cybersox on
  • DieterDieter Posts: 22
    barbult said:
    Dieter said:
    Hello,
    I had been looking for a product like this for a long time, which is why I bought it.
    Now, here is my question:
    Out of the 60,000 IM zip files, only 10,692 are listed in the catalog!
    What am I doing wrong?
    Does the folder you scanned contain all 60,000 DIM zip files, or were some possibly moved, or deleted, or downloaded to a different folder?
    All files are located in a folder on the NAS!
  • tsroemitsroemi Posts: 3,628
    Thanks for the really quick answer to my first question, and I'm sorry to join the hubbub with another one or two - but I keep my zips on external drives like others here and am wondering:
    - Is the Windows app version portable, can I install it on an external drive alongside the zips?
    - If it's locally installed, and I run it and have forgotten to plug in my DAZ zip drive, will it still know the results of the last scan it did? I'm generally guessing yes, since it's creating its own directory and thumbs and these will be stored, but I'm sort of worried that when it finds the actual drive not in place, it will just give out some error and overwrite the previous scan or something like that.
    Thanks again for taking care of all the questions here!
  • DoctorJellybeanDoctorJellybean Posts: 10,169
    If you can run Windows applications on an external drive, then yes. Just make sure that you copy the folder Content Catalog Windows under C:\Program Files\Doctor Jellybean\ with all the files and folder inside it.
    It will still show the scan results if you forget to plug in the DAZ zip drive. Just don't run a scan with it unplugged.
    Dieter said:
    barbult said:
    Dieter said:
    Hello,
    Are they all zip files? No rar or any other archive file format?
  • Is there a way/can there be a way to combine products/entries? There's an HDRI I own and it was split into 12 separate products in the catalog even though it's only one.
    That happens when a product is split into x number of files. I'll be looking at that.
  • Richard HaseltineRichard Haseltine Posts: 111,716
    barbult said:
    I think we should suggest that a forum mod move these Content Catalog discussions to the official PA thread. (Richard Haseltine is really skilled at doing that, although it can be a lot of work!) That is really where people would normally go to find questions and answers that have been posted here.
    Done (I think)
  • barbultbarbult Posts: 27,606
    Richard Haseltine said:
    Done (I think)
    Thank you, Richard. I haven't gone back to check, but I bet whatever you did was a help to clean things up and consilidate.
    @joanna I have found a solution for your usage. I'll provide more details once it has been tested.
    One immediate problem that I can think of with that are images. Unless you are not bothered with adding an image to each zip.
  • Hello,
    I just purchased and installed this.
    So if I understand this right, all this program does is scan .zip files, and not the actual installed database?
    edited August 20
    Hello,
    That is correct. Scanning the installed database would only discover the products you currently have INSTALLED. The purpose of Scanning all of your downloaded zip files is to capture everything you own, whether it is currently installed or not. Lots of us own older products or very large products that we don't keep continuously installed, but we still own them and want to be able to see them in the organized Content Catalog, in case they would fill a current need for a scene idea. If you don't download all of the products you buy, Content Catalog would not find the owned products you didn't ever download to your computer. They wouldn't be on your computer to scan. If you delete zip files after installing, Content Catalog won't be able to find those products either, because those zip files are no longer on your computer. You can resolve those two issues by just downloading the zip files again. You don't have to reinstall them. DIM can handle downloading Daz products again pretty easily.
    Post edited by barbult on
  • donniekeidicdonniekeidic Posts: 199
    @DoctorJellyBean - a couple little hiccups I'm finding:
    Any product from RDNA doesn't show the images properly and CC won't grab them either using the "Fetch thumbnail from DAZ" button. I actually have to manually select those thumbnail from the DIM thumbnail directory using the "Replace thumbnail" button for every single one by going to the thumbnails stored here: C:\Users\Public\Documents\DAZ 3D\InstallManager\Thumbnails
    Also, a lot of DAZ IM images that are shown seem to be "lower quality" images, not sure how else to put it. So that if I click on the "Fetch thumbnail from Daz" button, the image quality will actually get a slightly better image, sometimes the image is just sharpened slightly, other times its a completely different rendered thumbnail. I can only guess that by default the thumbnails are pulled from the DIM server, but when you pull images using the Fetch button, it seems to get thumbnails from a different Daz server with better newer thumbnail images. So why are the thumbnails differrent though? It seems to make no sense other than lack of server upgrades or maintenance I guess. And is there a way to make sure CC automatically pulls images from the better Daz server so we that dont have to update thousands of images manually? Or at least have it as a batch process.
    I think the default product thumbnails in Content Catalog come directly from the Zip file contents, not from a Daz server. I've seen really crappy thumbnails for some old Poser products, sometimes not even representing what the product contains. I too fetch a lot of thumbnails from Daz. It is kind of satisfying to see a bad thumbnail replaced by a much better one. I guess I am easily thrilled by small things. I haven't gone through my 10000+ products to seek out bad thumbnails.  I just fetch them as I notice the bad ones while using Content Catalog. Wait to you deal with products from a store like Renderosity, where the fetch isn't even available. Then I had to go to the website, pick a promo to use, save the image as a file on my computer and then Replace Thumbnail with that saved image. I then really appreciated the Fetch from Daz functionality for Daz store products!
    yes, but those zips are from a server, and why are those images not updated with the latest images? thats kind of my point. I'm not talking about DIMs that were even downloaded years ago, I can pull any of these DIMs right now and they will have the old images still. And regarding my 3rd party content, i don't have any of these issues because they all use the thumbnails I gave them when I created them using Content Package Assist, so all the thumbnails for 3rd party content is exactly what I expect. So oddly enough CC works better for my 3rd party content than my Daz content.
    By the way, these hiccups I'm not really complaining, I really love the app, I just want to point them out to DoctorJellyBean so he's aware and can maybe fix it in an update or offer a batch processing button for fetching images from Daz. A batch processing option would really be all that is necessary.
    ok, just for the heck of it i started opening up the RDNA DIMs, so none of them have runtime\support folders at all. Not sure why Daz would package them like that, so there is no thumbnail included with those DIMs at all. The only place those thumbnails exist is in C:\Users\Public\Documents\DAZ 3D\InstallManager\Thumbnails
    Maybe (just a guess, based on the crummy thumbnails I've seen for that old stuff) Content Catalog is just pulling any image it finds in the zip and using it as the product thumbnail, since there isn't a real one.
    I don't think there is any way Daz is going to go back and modify old DIM zip files to update thumbnails! That's not going to make them any money.
    Using Content Package Assist to package your 3rd party products turned out to be a very wise move! I've done some of that in the past, but not all products.
  • ElorElor Posts: 4,172
    It's the case with most products who were initially sold elsewhere before being transfered here.
    It doesn't obtain the initial images from the server. It firstly checks if there is an image in the Support folder, and uses that. If none available, then it searches the zip for images, e.g. Textures folder.
  • barbult said:
    bnstone_stone said:
    Hello,
    Bummer. I was hoping this would allow us to cataloge what we have installed and saved in an external DB.
    Not good, and not practical for my needs, will need to uniinstall this now.
    bnstone_stone said:
    barbult said:
    bnstone_stone said:
    Hello,
    Fill out a help request and ask for a refund if you can't use it. Then uninstall it and delete it.
  • LD1LD1 Posts: 189
    What happens once you have it scan everything and then you buy more? Will it know to just scan the new purchases or will it rescan the whole catalog (I have maybe 13000 items and I am sure it will take a long time to scan).
    Second question: I purchased it for the Mac and before I use it - do you have any idea on how long it would take to scan that many items (I am wondering if I need to start really early in the day to have it complete before bed time)?
    Thanks for your help
    Just run a normal scan and it will add the new purchases.
    The first scan will take a little while, long enough to make coffee or tea. Subsequent scans are much quicker, seconds.
    I don't now if this is feasible, but it would be great if we had a way of displaying the scanned zips by the folder they're contained in. I have my own system of how I sort them so I know where to look for stuff I want to install - for instance, folders for historical exteriors, historical interiors, modern buildings and so on. To have everything displayed together only sorted by name isn't really all that helpful I'm finding, because this way, I can't just see what, say, historical buildings I have and decide which to install. The existing tags don't help me much, they're way too unspecific, and I can't work through thousands of products to add my own tags. So just to be able to display them by the folder they're contained in would help so much really.
    edited August 26
    This product scans the downloaded DIM zip files and other store zip files, if you choose the folder where they have been downloaded to. It has no knowledge of what you have installed in DAZ studio or how you have organized them in the Content Library or Smart Content. If you mean your downloaded zip files have been sorted into multiple folders, then I would suppose it would be feasible to filter them by the folder they are in, as long as you scan each folder of zip files into Content Catalog individually. Dr. Jellybean will have to confirm whether that is a current capability or possibly something for a future update.
    In the current version, one can add multiple folders for scanning. There is an update coming, where you can select any of those folders and it will display the contents of that folder in the grid.
    Ah great, this is exactly what I need! (@barbult, yes, my zip files are organized in special folders, as I can't keep everything installed all the time and need some sort of system). Will wait eagerly for the update then. Thanks a bunch!
  • LD1LD1 Posts: 189
    edited August 27
    Hello,
    I have some questions for you:
    I just used the Mac version of your Content catalog for the first time and it said: “A creator could not be reliably determined for 48 products”.
    I looked in the manual to see where to go from there and the screenshot it showed had a button: “Resolve from Creator Database”. My Mac dialogue box does have the button, but it took me forever to realize it since the first and last word was missing from the button, so I thought it was for something else (see pict 1).
    Not knowing what to do, I pressed the: “Show me now” button. All of the 48 thumbnails showed up.
    I then looked in the Settings and found a:  “Resolve from Creator Database” option. I pressed it. Nothing happened.
    I finally clicked on the “Clear” button to make these 48 go away and to make the rest of my content thumbnails to appear.
    Question 1 - How do I get the remaining 48 thumbnails to show up again without doing a whole rescan?
    Question 2 - Some of the ones flagged were because the DAZ Store no longer carries them - understandable. But the others DID have creators listed (I double-clicked on their thumbnails which took me to DAZ’s content listed by SKU number).  And there it was, the author’s name for quite a few of the 48 products. This seemed strange to me. Well anyway, I manually filled in some because the creator’s name was in the content’s title. So why didn’t Content catalog find those names?
    Question 3: Could I have done something to make Content catalog find and include those names since the: “Resolve from Creator Database” didn’t work?
    BTW: I have also added a couple a picts showing problems with two drop-down menus.
    Help!
    811 x 636 - 133K
    Post edited by LD1 on
  • memcneil70memcneil70 Posts: 6,139
    Just a bit of DIM weirdness. I bought the Mac version of the program because I save my .zip files on that computer, but on my new Windows 11 laptop when I downloaded from DIM, I made the decision to not save .zip files. So I didn't buy the Windows version ot the program. I am considering a long term process of uninstalling and reinstalling and saving my .zips on an external hard drive but have not yet done that.
    But on the Windows11 DIM, the Mac version of this program is being listed as available to be installed?! I double-checked and I absoluted do not have Mac ticked to be installed by DIM on that computer. I have bought many programs that are OS specific, but this is the first time this has occured.
    It is not causing me any issues other than reminding myself to ignore it. But I thought I should mention it.
