New Year, New Sales Thread: Report Issues Here 4 "Reporting Only"
1737476787982
  • JohnMRJohnMR Posts: 11
    edited August 19
    frank0314 said:
    JohnMR said:
    This coupon code is working ?
    Your Free Gift
    Use code GET-ROWDY
    to get $10 off Daz Originals
    Any items i add in the basket from the provided link , the code is not working.
    What is happening ?
    Yes, it is working for me. Are you following the link provided and adhering to the exceptions?
    yes , unfortunately the same error
  • barbultbarbult Posts: 27,511
    edited August 19
    Yesterday's new releases are advertised at 49% off, but those prices are not honored in the cart. Something is broken in this store again.
    1020 x 1158 - 885K
    Post edited by barbult on
  • Cris PalominoCris Palomino Posts: 12,978
    Barb, where are these that I can't find them?
  • ElorElor Posts: 4,116
    It's on the Super Token Sale page:
    https://www.daz3d.com/super-token-sale
    But on my end, I saw all of this products with the usual new release 30% discount, so I suppose it was fixed.
    ah, no wonder I couldn't find it, thank you.
    I still see the incorrect prices, but I suppose it is cached on my computer now.
  • frank0314frank0314 Posts: 15,102
    Brysey said:
    frank0314 said:
    Your Free Gift
    Use code GET-ROWDY
    What is happening ?
    Not for me either and I tried several combinations since Sunday. The selection is all Daz Original now without any + but does include Outlet, which I assume is also a no-no.
    Are you making sure it's not a product marked "New"?
  • Matt_CastleMatt_Castle Posts: 3,257
    NEW-FLASH-3 code is still being advertised in DIM, but does not work (and no, I haven't previously used it).
  • FantastArtFantastArt Posts: 412
    same here
    I let them know. Thanks for pointing it out
    edited August 20
    In the end I founded why the code was not working for me.I added only discouned items, less than 10 $, and unfortunately I can't purchase them as free items.
    If I had applied the code to a full , non-discounted item it worked.
    Thank you DAZ3D, but now I can't spend any more money in 3d models.
    Thank you,  to all the people which had responded to my message and had tried to help me.
    Use code GET-ROWDY
    Post edited by JohnMR on
  • jmucchiellojmucchiello Posts: 2,114
    Tokens are not working
  • BeulahBeulah Posts: 5
    In what way aren't they working?  Do you have a screenshot of the cart they aren't working on
    In what way are they not working?
  • MickyBeMickyBe Posts: 365
    Same here, tokens indicated as applied on item in cart
    but no discount on price ...
    1416 x 781 - 294K
    Reporting.
    Tokens should be working now.
    Thanks, I confirm it works now.
    Use code GET-ROWDY
    That's odd. I had no trouble using the code, with an item that was discounted to $10. Sorry you couldn't get it to work.
  • Rod Wise DriggoRod Wise Driggo Posts: 2,344
    edited August 22
    PICK-A-FAVE not working with new releases? If so it's not mentioned in the small print.
    Post edited by Rod Wise Driggo on
    There is no new release in the eligible selection, so why mention the coupon won't work on them?
    https://www.daz3d.com/pick-a-fave#filter_inWishlist=yes&filtered=1
  • vwranglervwrangler Posts: 5,048
    edited August 22
    PICK-A-FAVE isn't working with the items in the eligible selection, either. I've tried several items on that list, and every single one gets "Coupon code not valid". Tried cut-and-paste and typing directly, and neither works. See attached.
    selection options
    cart
    1504 x 536 - 184K
    1470 x 743 - 126K
    Post edited by vwrangler on
  • caravellecaravelle Posts: 2,776
    Same here.
  • KinichKinich Posts: 941
    The code is 'PICK-A-FAV', no 'E', works for me.
  • EboshijaanaEboshijaana Posts: 576
    Not working here, either.
    Are you using PICK-A-FAV or PICK-A-FAVE? The latter is incorrect. Otherwise, it's working on my end.
    PICK-A-FAV worked.
    Ah, OK. I'd have sworn that it said PICK-A-FAVE. But yes, PICK-A-FAV works.Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,420
    I think it did, initially (and no, I did not type that page).
    edited August 23
    laughYour comment made my day!
    Edit: Oops I had to correct and unintentional typo in my response. An intentional type may have even been better, though.
