[Released] Now-Crowd Billboards - School Life and Asian School Life (2 Products) [Commercial]
1246
    I am attaching the log files. I think that the result without pressing Preview before Accept is the correct result. That method retains the horizontal and vertical rotations that had been selected in Change Billboard Angle. Pressing Preview seems to reset those rotations back to zero. But honestly, I don't know what your real intent was. I just know that pressing Preview befor Accept changes the final result.
    The first log file is Change Billboard Angle followed immediately by Orient Billboard, without preview.
    The second log file is Change Billboard Angle followed immediately by Orient Billboard, WITH preview.
    txt
    txt
    DS4 log Billboard angle and orient.txt
    10K
    txt
    txt
    DS4 log Billboard angle and orient WITH PREVIEW.txt
    12K
    Now that NorthOf45 has the scripts working, perhaps he can see if he can reproduce the "Preview vs. no Preview" different results.
    This is the scenario 1:
    1. Load a Now-Crowd Billboard into an empty scene. I used the School Life Billboards.
    2. Select the loaded Billboard in the Scene pane.
    3. Run Now-Crowd Billboard Change Billboard Angle script.
    4. Check all the options in the Options tab.
    5. Uncheck Live Preview in the Angle tab
    6. Set Horizontal to 60.
    7. Set Vertical to 30.
    8. Click Accept.
    9. Run Now-Crowd Orient Billboard script.
    10. Uncheck Perpendicular to Ground Plane.
    11. Uncheck Live Preview.
    12. Click Accept.
    13. Screenshot or render the result for comparison with Scenario 2.
    14. Delete the Billboard from the scene.
    This is the scenario 2:
    5. Uncheck Live Preview in the Angle tab.
    8. Click Accept.
    12. Click the Preview button.
    13. Click Accept.
    14. Screenshot or render the result for comparison with Scenario 1.
    15. Delete the Billboard from the scene.
    For me, these two scenarios produce different final results. The only difference in the scenarios is whether the Preview button was pressed in Orient Billboard.
  • NorthOf45NorthOf45 Posts: 5,924
    Okay, I had a little time to play with this. Following your instructions using the same billboard, Scenario 1 seems to work okay. Figure turns to face right, seen from slightly above. Having all options checked will orient the billboard to the user already, so you shouldn't need to use the orient billboard, but it isn't necessarily excluded from consideration. Working on Scenario 2, I see that the angles are reset to zero. I explored a bit and found that pressing Preview a second time also clears the angles, so when you Accept, the billboard has already been reset. Actually, making a second change to the billboard, repeating the steps in Scenario 2, the billboard will revert to the previous angles, not necessarily zero. That second action in Orient Billboard seems to be the problem, either Preview, Accept, or Preview, Preview.
    Same behaviour in DS4.24 and DS6.
    (Won't have much time to play with DAZ for the next week, so I hope you can get some answers).
    Thank you very much for confirming the issue.
  • RiverSoft ArtRiverSoft Art Posts: 6,977
    I can confirm the issue too... and a fix: Now-Crowd Scripts Update.zip
    edited August 18
    I did a quick test in DS6 Public Build. I loaded some Billboards and ran Now-Crowd Change Billboard Angle. I used a negative Horizontal value and a positive Vertical value. I had all option checked on the Options tab except Live Preview. I did not click Preview. I just clicked Accept. In the Viewport, none of the billboards were rotated. They should have been rotated, because I had Orient Billboard to Camera checked. So, this product does not appear to be fixed. I didn't even get as far as trying Now-Crowd Orient Billboard, because Now-Crowd Change Billboard Angle didn't seem right. Are we now REQUIRED to do Preview in Now-Crowd Billboard Angle, before clicking Accept?
    Post edited by barbult on
    Strange. It works perfectly for me. No preview required. What did the log say? Perhaps it loaded the wrong support units?
    I didn't save the log. I'll rerun it today and save the log and some screenshots of my settings and results.
    These are the steps I performed in DS6.25.2026.19821 Public Build (Beta):
    1. I loaded Now-Crowd Billboards School Life/Couple Embracing 01
    2. I ran Now-Crowd Billboards/Now-Crowd Change Billboard Angle in the product Now-Crowd Billboards School Life
    3. I clicked on the Options tab
    4. I clicked on Select to select the Billboard in the scene
    5. I took a screenshot of my settings (note the Live Preview is not selected)
    6. I clicked on the Angle tab
    7. I moved the Horizontal and Vertical sliders around and settled on Horizontal -48 Vertical 51
    8. I took a screenshot of the script window and the viewport
    9. I clicked Accept (I did not click Preview before Accept)
    10. The Billboard in the viewport changed angle slightly, but not to match what was shown in the script window.
    11. I took a screenshot of the final viewport result.
    Screenshots are attached. The log is attached. Note that there are several WARNING messages in the log file.
    Thanks for taking a look at it.
    1135 x 1336 - 704K
    1060 x 1364 - 855K
    852 x 1257 - 626K
    txt
    txt
    2026-08-18 billboard log.txt
    4K
    The log reports something that might point to a configuration error. Can you run this dsa script and report the log? You can run it from anywhere.
    dsa
    dsa
    Diagnose_NowCrowd_Install.dsa
    5K
    I get the same results following those steps. Re-opening the Change Billboard Angle script shows that the angles have both been reset to zero. With Live Preview set, it does the same thing. Clicking Preview seems to latch in the values, and subsequent changes in angles are applied without needing to click Preview. If you deselect and then re-select the bilboard from the Options Tab, the angles show zero again, but the Billboard has not moved from the last input and will not move to the zero angles, probably because the angles used are still present, but not displayed. If you re-select the billboard in the scene, the current angles are displayed.
    (The slight change in billboard angle is probably due to the Orient Billboard to Camera option. The default Billboard load and your viewport/camera might not line up at first.)
    edited August 20
    Sorry for the slow response. At first I didn't understand how to run this. I figured out I had to download it to my computer and drag it from that folder into the DS6 Viewport. It reports that I am missing two configuration files. Neither of those files was included in the recent script update zip file that you posted here in the forum. They are also not included in the DIM zip package.Where are they supposed to come from? Are we finally homing in on the problem?
    I see NorthOf45 gets the same results I do with the test steps I reported.
    587 x 732 - 82K
    txt
    txt
    2026-08-20 Now-Crowd Install diagnostic Results.txt
    3K
    I also get the same results about missing scripts in 2025Common, however equivalents do exist in the Common folder.
    Well, that confirmed it is not an installation problem. (The two files were for Now-Crowd Utilities). I have added more debug statements to the files in the zip. Please re-download and try again, showing me the log. I really apologize for all the trouble.
    Were you intending to attach a new script? Did you update the old script in the previous post? I re-downloaded the previous one, but I don't see added debug statements.
    txt
    txt
    log.txt
    4K
    I updated the zip with the Now-Crowd scripts so they have more debug statements:
    Oh, I misunderstood. I thought you updated the diagnostic script.
    Here is the new log file. I set horizontal angle to -41 and vertical angle to 41. I got an error message (attached) when running Change Billboard Angle. I got this error twice, but now I don't get it anymore. In spite of the error message, the script seemed to continue and might have performed properly without me clicking Preview before Accept. Except it seems strange the Change Billboard Angle chose -30 as closest to -41, but chose 45 as closest to positive 41. Why is it not -45 and 45?
    txt
    txt
    more debug log.txt
    26K
    502 x 236 - 21K
    636 x 626 - 71K
    659 x 1251 - 774K
    edited August 24
    Is your N drive a network drive? That might be causing the intermittent no image returned by Daz problem. Regardless, I updated the scripts to handle it more gracefully. Please pull from the link again
    Post edited by RiverSoft Art on
    N drive is not a network drive. It is just a normal hard drive in my computer.
    The new log file is attached. I got an error when running Change Billboard Angle, with a different message displayed this time. The log shows a fallback succeeded, followed by a script error. I think the script error is what caused the error message to be displayed. In spite of the fallback succeeded, the resulting billboard rotation was incorrect, probably because of the script error.
    Then I just ran Change Billboard Angle again and it worked correctly that time. I am wondering if the failure always occurs the first time it is run after starting DS6, so I need to try that a few more times to see if it is a consistent pattern.
    txt
    txt
    DazStudio_log_20260824_095000.txt
    6K
    870 x 1203 - 621K
    Twice the error occurred the first time I ran Change Billboard Angle right after starting DS6 Public Build. After that it worked OK right after starting DS6 Public Build. The fallback might work, if it wasn't followed by the script error. Maybe another round of script update is needed to resolve that script error.
    I'm running a diagnostic scan of the drive, to see if it finds any problems with the drive itself. The initial key statistics say "No SMART thresholds tripped". The media scan will take more time to complete.
    I get the impression it is an initial value problem. Once it is set to something valid, it continues without error.
    Maybe so. I hope my drive is OK. Media scan is continuing. It is good to check these things now and then anyway.
    edited August 24
    I am unable to reproduce this on my machine. I think it might be a caching problem. My latest theory is that your drive might be slow? I was setting the image map on the plane and then re-reading it immediately - on your system, it is null sometimes. Once the cache is initialized, everything works. That said, I have re-written how it works so I avoid the re-read. Hopefully that will fix all your problems. Please redownload again. Sorry for all the back and forth.
    No problem. Fixing it once and for all will be of great benefit.
    My library is on hard disc, so, yes, slower than SSD (too big for an affordable one these days), so you might be onto something.
    Yes, the drive is 5400 RPM, so on the slower end. I haven't had other problems with it, though. It has my DS Content Library on it, so lots of small files.
    The back and forth doesn't bother me either. Sometimes that is what it takes to home in on a problem. I've downloaded the zip again, but I won't be able to try it until later today after I return from an appointment. I'll let you know what happens. I'm eager to try it. I really appreciate the way you support customers and sincerely work to fix problems we have. It makes you one of the best.
    Okay, this latest patch seems to work properly. I am unable to reproduce the problem in DS4.24 or DS6 (the billboard always moves to the input angles, with or without Live Preview, or clicking Preview or not). Let's see what barbult has to say...
