Released: HedgeMaker [Commercial]
124»
  • TotteTotte Posts: 15,138
    Elor said:
    I didn't think it was possible to have a mistake in the name of the package but not in the name of the product (likely because the script I'm using to create package does get all the needed informations inside the .dsx files containing all the metadata), but yes, I saw the problem in DIM.
    As plugins are much more special when packaging, a lot of manual steps are involved.
  • ImagoImago Posts: 5,786
    I have a problem with the product: The Hedge Maker can't find any set, so I can't use it bit the Set Creator seems to find and manage them correctly.
    this happens in both 4.24 and 6 versions.
    Where did you install HedgeMakler, what Studio Library? Did you install it in another library than the default one?
    The sets are in /data/BWCTotte/HedgeMasker/HMData...
    edited August 9
    And now do you set the filter?
    1566 x 80 - 29K
    Post edited by Totte on
    I Installed it into a personalized path, in a secondary SSD (it's a disk dedicated only to DAZ's libraries. anything else works fine). I used the DIM to install it.
    The .json files are in the folder you indicated.
    Also, I tried every option in the interface, nothing appears.
    This sounds weird, never heard anyone having issues with that before.
    A few more questions:
    - What OS version?
    - What filesystem on the dedicated SSD drive?
    edited August 10
    - What OS version?
    Windows 10. The SSD is NTFS.
    In the meantime I found out that if I open the sets in the Sets Creator script and overwrite them as "3Delight" and "Tree/bushes" they finally appear in the sets list of the main script. They appear on any combinations. Even if saved as 3Delight sets they can be seen in the IRay setting.
    Post edited by Imago on
    edited August 10
    If you use AnyType, all should be seen. OK  made two new sets, both Iray, one Tree/Bushes and one Flower
    Created a stump set
    Checked it in HedgeMaker
    Created a flower set
    1680 x 1336 - 678K
    1848 x 2394 - 851K
    1680 x 1336 - 675K
    1702 x 1630 - 494K
