Viewport VS Aux Viewport
What's the difference and which view is the render done from?
  • Richard HaseltineRichard Haseltine Posts: 111,688
    Aux Viewport was added to support the 3Delight interactive preview render, to allow a lower resolution preview without aving to do a full render/spot render in the main viewport. Now that 3Delight is no longer part of DS it lacks the extra controls it had for that, but it can still be used as a preview render pane without haveing to switch over the main viewport.
  • XtraDimensionalXtraDimensional Posts: 564
    edited August 5
    I often use the aux viewport for another angle when I'm doing fiddly stuff like recreating a specific person's face.
    I know we can split the main viewport, but being able to have the full real estate od the main zoomed in while having a pulled back view or a profile view on the aux is extremely helpful.
    I have had some confusion as to which window the renderer takes, so I usually just set them both to the same camera or tab out of the aux before I hit go.
    Post edited by XtraDimensional on
  • jmucchiellojmucchiello Posts: 2,338
    I had no idea the aux viewport had a specific purpose. I just thought is was superfluous. I general flip between "2 bottom, 1 top" and "2 right, 1 left" depending on the orientation of the render.
  • TimberWolfTimberWolf Posts: 398
    @XtraDimensional
    The render is done from whichever viewport is currently 'active'. If you click in the viewport(s) or the aux viewport window you'll notice a border outline appears in the highlight colour of whatever theme you've picked. This shows which pane is active and which will be used for rendering.  Any pane can have any camera (or perspective view) selected and Studio will use that if it is selected.
  • Drogo NazhurDrogo Nazhur Posts: 1,344
    TimberWolf said:
    @XtraDimensional
    Thank you. This opens up new possibilities. Hard to believe that I've been using this for over a decade and only realized this now.
  • TomhipTomhip Posts: 632
    edited August 6
    I love to use Aux viewport to move Spotlights while watching effects from camera in main one.
    Post edited by Tomhip on
    Curious: Does this mean your main viewport is usually set to "Single View"? I usually have spotlights in one of the "right" or "bottom" quadrants.
  • bluejauntebluejaunte Posts: 2,274
    It's faster to have Iray preview in Aux and pose etc. in main, as opposed to both in main. You should try it sometime.
    I don't pose with iray preview. If i had multiple monitors, that might work. But I need the scene window and the parameters window open and the content library open when I'm posing. Where would the aux window go?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,647
    I would prefer an additional content tab over the Auxiliary viewport
    so much scrolling
    fortunately D|S does support drag and drop from Windows Explorer so I usually have a few windows open as well
  • crosswindcrosswind Posts: 10,322
    I don't pose with iray preview either but sometimes I check DoF settings in Aux viewport which is docked to a separate pane group under Content Library. Then I collapse the group if I don't need it ~~
    2560 x 1392 - 605K
  • garrett_3dgarrett_3d Posts: 997
    I don't use Aux Viewport at all, it's too small to be of any practical use as I rarely do anything close up.
    I just do that in the main view port with 2 right, 1 left or 2 bottom, 1 top. I have a 32 inch monitor. I don't need the figures that big.
    Yeah mine is nice and big on a separate left monitor. I've had multi monitor setups for well over 20 years by now. Having 1 is quite unimaginable at this point. Also why BJ Camera Manager has the Aux viewport so deeply ingrained in its design smiley
    Yeah Mian view is Camera only, Aux view is a small window on side Panel
    LOL I wondered about that when I saw CM. It just isn't something I use much. I also tend not to hide cameras unless they prevent me from clicking on something.
