save a shader material weird question
WendyLuvsCatz
I don't know what changed or when it changed, but I used to be able to save a shader/material preset I could apply to any surface
now in the latest DS4.24 apparently I cannot,
it will not apply to surfaces selected no matter how I save it
its just DAZ Uber with a base and normal texture, saving as a shader rather than materials preset, I thought it should apply to anything be it 3Delight shader originally. a Poser object etc
but it won't
Did you check all the nodes in save options when you saved the shader preset ?
well I actually got it to work since and was returning to say so
by NOT applying it to a DAZ cube primitive to save it
it doesn't like primitives apparently
