[Released] Look At Me III [Commercial]
124»
  • Has anyone had an issue with Look at Me III not working correctly and found a fix or workaround for it?
    For reference: I'm running Daz 4.24 Publishing Build Beta on Windows 11.
    I've had Look at Me II for a long time. It has always worked well for me until recently when it started resulting in one eye a lazy eye for Gen 8, 8.1, and 9 characters when I used "Look at Camera."
    So I decided to buy Look at Me III to see if that would work better. Except I've not been able to get it to work. Initially I simply installed it via DIM as I would any product. When I selected my Gen 9 character and double clicked on Look at Camera script,  get the error message: "An error occurred while reading the file. See the log for more details." I've perused the log but I'm not sure what they information is telling me other than "script failed to load." I get this same error when double clicking on any of the LAM III scripts.
    I've troubleshooted in the following ways, but nothing has helped:
    Uninstalled Look at Me II
    Uninstalled and reinstalled Look at Me III
    Restarted Daz Studio
    Anyone know of anything else I could try to resolve this issue? I'll paste some of the log info below:
    2026-07-23 14:14:08.850 [INFO] :: Loading script: D:/Dazzies Assets/Daz 3D/assets/content/scripts/riversoft art/look at me iii/look at camera iii.dse
    2026-07-23 14:14:08.851 [WARNING] :: Failed to load script: D:/Dazzies Assets/Daz 3D/assets/content/scripts/riversoft art/look at me iii/look at camera iii.dse
    2026-07-23 14:14:12.400 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 03060 iterations after 01:02.593.
    2026-07-23 14:14:18.643 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 03379 iterations after 01:08.836.
    2026-07-23 14:14:25.521 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 03730 iterations after 01:15.714.
    2026-07-23 14:14:33.179 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04116 iterations after 01:23.372.
    2026-07-23 14:14:38.912 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Updating scene.
    2026-07-23 14:14:38.912 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Updating scene took 201.500 us.
    2026-07-23 14:14:38.918 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2026-07-23 14:14:38.919 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2026-07-23 14:14:38.923 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 2 device(s):
    2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti)
    2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU
    2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2026-07-23 14:14:38.926 Iray [INFO] - IRAY:RENDER ::   1.20  IRAY   rend info : CPU: Allocated 556.285 KiB for frame buffer
    2026-07-23 14:14:38.931 Iray [INFO] - IRAY:RENDER ::   1.19  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti): Allocated 25.612 MiB for frame buffer
    2026-07-23 14:14:38.931 Iray [INFO] - IRAY:RENDER ::   1.17  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti): Allocated 2.094 GiB of work space (2048k active samples in 0.000s)
    2026-07-23 14:14:38.931 Iray [INFO] - IRAY:RENDER ::   1.17  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti): Optimizing for cooperative usage (performance could be sacrificed)
    2026-07-23 14:14:38.989 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iteration after 53.016 ms.
    2026-07-23 14:14:38.997 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2026-07-23 14:14:39.053 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 101.519 ms.
    2026-07-23 14:14:39.055 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2026-07-23 14:14:39.119 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 156.869 ms.
  • butterflyfishbutterflyfish Posts: 1,824
    I also get that error with Look at Me III. I've had it since March, and it only started doing this recently. Look at Me II still works fine. I'm running the beta of 4.24.0.3 with Windows 11.
  • Seeker Stock ArtSeeker Stock Art Posts: 84
    edited July 25
    Thank you for weighing in. Did you decide to uninstall LAM III and stick with using LAM II for now? Have you put in a bug report with Daz3D support as yet? Or heard from Riversoft on any troubleshooting ideas? And when you say it only started bugging out recently for you, do you recall any changes that were made around the time it stopped working? Say, for example, upgrading to a later Daz Studio beta version, etc.?
    Post edited by Seeker Stock Art on
    I haven't put in a bug report yet. It didn't even occur to me. I'll try that. I've been on 4.24.0.3 since it released. It's the last version with 3DL, so the one just before the current version. I've installed a ton of stuff, plus upgraded from DAZ+ to Premier since the June sale, so it could be a lot of things interfering.
    This is all I have in my log:
    2026-07-25 02:09:39.961 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): recv failed errno=10054
    2026-07-25 05:11:09.155 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): recv failed errno=10054
    2026-07-25 11:14:21.883 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): recv failed errno=10054
    2026-07-25 16:39:59.976 [INFO] :: Loading script: E:/heidi/My DAZ 3D Library/Scripts/RiverSoft Art/Look at Me III/Look at Camera III.dse
    2026-07-25 16:39:59.977 [WARNING] :: Failed to load script: E:/heidi/My DAZ 3D Library/Scripts/RiverSoft Art/Look at Me III/Look at Camera III.dse
    2026-07-25 16:40:28.283 [INFO] :: Loading script: E:/heidi/My DAZ 3D Library/Scripts/RiverSoft Art/Look at Me III/Look at Camera III.dse
    2026-07-25 16:40:28.283 [WARNING] :: Failed to load script: E:/heidi/My DAZ 3D Library/Scripts/RiverSoft Art/Look at Me III/Look at Camera III.dse
    2026-07-25 17:54:43.988 [INFO] :: Loading script: E:/heidi/My DAZ 3D Library/Scripts/RiverSoft Art/Look at Me III/Look at Camera III.dse
    2026-07-25 17:54:43.988 [WARNING] :: Failed to load script: E:/heidi/My DAZ 3D Library/Scripts/RiverSoft Art/Look at Me III/Look at Camera III.dse
    Not very useful, I'm afraid. Google's AI thinks it's dropping a connection to DAZ, as if I'm not logged in (except I've tried it with and without being logged in). IDK where to go from here.
    It's working at last for me! The steps I took:
    Exported out my custom categories
    Reimported my metadata in content database
    Upgraded to the latest beta publishing build (4.24.0.4)
    Ah, OK. I don't use smart content, so I just updated the beta to 4.24.0.4 and it works again. No more 3 Delight, but this works now, and I didn't use that anyway. Thanks!
  • Sure thing! Glad the upgrade worked for you too.
