CB Raven for Genesis 8.1 Female
I hope someone might be able to help with this rather odd problem.
I recently bought both the CB Raven character and the CB Raven outfit. They look great together in the promos, but, try as I might, I cannot get the outfit to load onto the figure properly. The CB Raven outfit loads fine onto other figures and other outfits load on to CB Raven, but they just do not seem to work together, although they are obviously supposed to.
Doing a "Google" the best I can find is that there may be some sort of conflict due to the figure being 8.1 and the outfit being for both 8 and 8.1. If so, how do I solve that?
  • garrett_3dgarrett_3d Posts: 1,038
    Are you selecting the correct outfit? I have two versions, one for G8 and one for G8.1.
  • felisfelis Posts: 6,600
    What is happening when you try. Do you get an error?
    edited July 18
    I just tried to load it onto G8F, G8.1F and Raven.
    The morphs in the clothing set to fit to CB Raven is wrongly created, and they don't match the character.
    If you delete (or move them to somewhere else) these ,CB Raven fit morphs, the clothing should fit, as the morphs then will get autogenerated. For sure QA hasn't tested the clothing on Raven.
    Post edited by felis on
  • crosswindcrosswind Posts: 10,344
    edited July 18
    I remember I've seen the similar issue before... the vendor fixed FBM on a clothing, saved the morph asset but then they modified the character's shape again but didn't further fix the FBM ~~
    Jus fill a ticket to report the issue ~
    Post edited by crosswind on
  • StargazeyStargazey Posts: 285
    On checking I only have one version of the outfit, for G8, so that may well be at least part of the problem!
    Thanks for all the replies, it looks like my best bet is to put in a ticket and hope it gets fixed, as it looks like there's more to it than just a matter of using some other settings.
    edited July 18
    Genesis 8 clothing will fit Genesis8.1, so there should only be 1 set.
    Here is what the clothing look like on Raven, with the faulty morphs removed. Autogenerated morphs instead of the (faulty) premade
    But please raise a ticket.
    1250 x 1000 - 2M
    That's what I thought, but I have had problems with some other outfits that don't seem to work on both 8 and 8.1 figures!
    Anyway, I deleated the morphs, as you suggested, and now all is good, so many thanks for the help.
    I will raise a ticket anyway, as you really shouldn't have to mess around like this to get clotthing to fit properly.
    edited July 19
    If you have problem with a clothing, name which and on which character the issue occour, so it can be clarified.
    Genesis 8.1 clothing will not fit Genesis 8 (activate the autofit dialogue), so clothing should never be saved with G8:1 as base.
    Making and saving the clothing with G8.1 shouldn't be a problem while setting the correct Preferred Base to G8 before saving the figure asset is important ~
