Matt Castle's Freebie thread (NEW: Additional fits for Elysion Grace Suit)
Matt_Castle
I've decided to merge my multiple freebies threads to have one consolidated hub for sharing stuff. Several posts incoming...
EDIT:... and I believe now up to date, including the new Water Park Slide Addons: https://www.daz3d.com/forums/discussion/comment/9241441/#Comment_9241441
Post edited by Matt_Castle on
Additional fits for dForce Trumpet Dress (G8F version)
Original Thread
Download Link: https://www.daz3d.com/forums/uploads/FileUpload/02/14ec428cdf14ca32280deac0b9e8d1.zip
Genesis 8 Centaur dForce Clothing Aids
Original Thread
Dforce Gris Swimsuit for G8F
Original Thread
Multi Bulge for G8M, G8F and G9
Original Thread
Torso UVs for Genesis 9 Anatomical Elements
Original Thread
Pseudoclones for Centaur 8 Female
(No original thread, was posted in some other thread somewhere I can't be bothered to find)
These are clone shapes that provide Centaur 8 Female the ability to auto-fit Horse 2 or Horse 3 assets (here Rina is wearing https://www.daz3d.com/costume-set-for-horse-3 with textures from https://www.daz3d.com/versatility-for-costume-set-for-daz-horse-3), although technical limitations mean that their usage is somewhat more involved than standard autofit - instructions are in the included Readme.
I may update these at some point to include Centaur 8 Male and Centaur 9, or indeed adapt my shapes from converting from Dog 8, but no promises.
Download: https://www.mediafire.com/file/sw8t75n4ifpa5o9/Centaur_Clones_20230114.zip/file
Genesis 9 Feminine Nipple Position Morphs
In response to persistent complaints in a thread about where G9F's nipples were positioned/pointing, I created these morphs to allow users to move their position on the chest.
Download: https://www.mediafire.com/file/9dx1dfkgkkzber7/G9F_Nipple_Position_20240328.zip/file
Water Park Slide Add-ons
... and finally getting to something new and the reason I was consolidating the threads.
I like Modu8's Water Park product, but was a bit disappointed by the curved slides being bone dry, so it took me a long time to get around to adding water to the slide and doing a scene with it.
In this back, you get smart propped water that runs the whole way down the slides...
... and also the water outlets I made but ended up ultimately not using:
You also get a morph that slightly changes the shape of the slide (I felt the original shape had some of its turns banked the wrong way and was liable to have people hit their heads on some of the infrastructure, as well as a matching morph for the water.
It does not come with the fine splashes from the render (those are individually posed splash props) or the foam (which is applied via a geoshell using a material from one of KindredArts's sets - https://www.daz3d.com/iray-foam-and-bubbles or https://www.daz3d.com/wetfx-decal--shader-kit - I forget which). However, the water has a simple top down UV projection, so should reasonably take any seamless material or geoshell without issue. (By default, the water uses a bump map from the set's ground plane, which actually works well enough).
Download: Attached below.
Centaur 9 dForce Clothing Aids
I've transferred my existing dForce simulation Aids for Genesis 8 Centaurs over to Centaur 9.
Now with apologies, this won't let you do the full scene above, as it doesn't include any of the tools necessary to fit things around the hindquarters of the centaur, nor the functions to fit shoes to them. (The people on the Daz Slackers Discord are weirdos and these days if I do a centaur render that isn't fully dressed, I get facetious comments).
However, it will help you drape dresses, coats or cloaks over the forequarters of Centaur 9.
Download below, assuming attachments aren't broken again...
For those who want their cowtaurs to have their udders freely hanging out, I have been working on the Elysion Grace Suit to address some poor auto-following on the new Axel 9, male and female minotaur, bulltaur and cowtaur shapes.
This has added support to all parts of the Genesis/Centaur 9 outfit, not just the centaur pieces, so if you want human Axel rocking fishnets and heels, yes, I have added his shape to the human boots.
(As these sets released so close together I wanted to address the issue, if only for my own purposes/amusement).
I've also added conditional grafts to all versions of the heels to let you hide the foot plates and/or stockings in order to give more flexibility about how you use them. (I doubt most of you have many other centaur high heels to use).
(Please note that there's something strange about the cowtaur tail that wants to make the skirts explode when you try to simulate them. I don't know what it is, and unfortunately I couldn't find any way to resolve it other than to hide the tail from the simulation when you're trying to dForce the skirts).
Thanks for all of the freebies - much appreciated.
