Bryce Requirement -- EPIC SCIFI: Space Station Construction Kit
csaacsaa Posts: 1,082
I bought the EPIC SCIFI: Space Station Construction Kit recently, seeing how the product description declared: "The models are included in both native Bryce format, and as standard .obj files." I understood that to mean I could use the OBJs straight away. However, during installation, DIM asked for the location of Bryce (7 Pro, 7 or 6), which I hadn't purchased. As far as I could tell, DIM wouldn't proceed with the installation. Interestingly, the link to the PA minhea only led to an Oops page.
Is there any way to work around the Bryce hard requirement and install the product? If not, and I misunderstood the product description, I'm filing for a refund. It's a pity, considering the file manifest shows a good amount of content -- 46 or so models in the product, both OBPs and OBJ/MTLs.
Cheers!
Post edited by csaa on
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Try adding bryce to the Applications tab of the Advanced Settings dialogue, even if you don't have it - just pick a convenienent folder. DIM  won't validate the installation actualy contains the application. I just had a look and the OBJs are in subfolders of the Bryce structure, which is surprising - you could of course do what I did and download the zip directly from your Product Library, then just extract the OBJ folder (and a Textures folder with some maps)..
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,821
    this
    my DIM is set to download photoshop brushes into my Gimp directory
  • GordigGordig Posts: 10,839
    I was going to suggest you just install Bryce because it's free, but that doesn't appear to be the case, at least not anymore.
  • csaacsaa Posts: 1,082
    Richard Haseltine,
    Downloading the ZIP from my Product Library did the trick. Thanks.
    Cheers!
