Smart Enhancing System - Breast Control for G9 Bad Install?
in The Commons
Anyone have succeess getting this installed? DIM says files are installed, but nothing is there in DS, and no folders are present for the product in the library
Look here: /People/Genesis 9/Poses/AlFan/Smart Enhancing System — Breast Control/
Also, check the readme to find out what files come with an asset: https://docs.daz3d.com/public/read_me/index/116000_116999/116771/start
When I installed it via DIM for some reason it didn't show up in DAZ after install, not in the Poses/AIFan folder, nor under the G9 Pose Controls/AIFan. I grabbed the manual download file, extracted the files into my DAZ content directory, and now it shows up, so maybe give the Manual Download a go.
Same Problem here. It wont show either in the AI sub folder (I only see the normal Smart Enhancing System without Breast Control) and it wont show up in the Posing plane on the right either. DIM download and manual download didnt help. First Product that does this so im a bit confused
installed via DIM and not showing as installed.
The folders for the manual download are empty, so I'm guessinng that's the same for the DIM versionb as well.
I have extracted the different folders inside the zip archive downloded with DIM and I have installed them manually. It works. I think it's the "---" in the data folder name that causes the error because the files are not installed in the correct the folder.since the name is truncated.
They are installed in the folder:
/data/Daz 3D/Genesis 9/Base/Morphs/AlFan/Smart Enhancing System
instead of:
/data/Daz 3D/Genesis 9/Base/Morphs/AlFan/Smart Enhancing System — Breast Control/
So you can either extract the different folders and install them manually or rename the folder correctly.(add " — Breast Control" after the folder name (don't forget the space before the ---).
My old version of winzip can't extract anything due to the file names. How the heck did this get past QC?
If you can't extract the files, you can either download a freeware that will do it or you can do this:
- Create a temporary base directory/runtime in daz studio.
- Tell DIM to install the files in that directory/runtime and take the files out of it.
- Install the files manually in your usual runtime.
- delete the temporary base directory/runtime.
Just a suggestion, of ourse. :)
Tried extracting into a temp install folder and the extract failed, throwing an error on every file. Had to nuke Winzip with task manager. Have to wait for Daz to fix I guess. Will file a ticket.
has anyone created a ticket about this issue?
https://www.daz3d.com/forums/discussion/765771/smart-enhancing-system-breast-control-for-genesis-9-can-t-find-it#latest
