Looking for a double-sided hair salon hand mirror
DoctorJellybean
[Looking for a double-sided hair salon hand mirror] The various salon products in the store don't seem to have one
Will this work?
I eyeballed the size.
Perfect, thank you! I can always resize it if needed.
What is the purpose of a double sided mirror? Is one side magnified?
My description is wrong, it should be double-handed not sided. Mind you, double sided is also useful as one side could be as you suggested magnified.
My aunt was a hairstylist and owned her own shop, and she had double-faced handheld mirrors at all her stations for all the employees. One side was a regular mirror, and the other side was magnified.
Here is the mirror. It has 2 surfaces, frame and mirror.
If you want it single sided, I can fill out one side.
Thank you.
Only if you have the time, one sided only is a good option to have.
Moved to Product Suggestions as it is a request for, not an offer of, a freebie.
Attached is a zip with the original mirror and one with mirror on one side.
Thank you once again!
Tried to make one side slightly enlarging
Just a note for why an enlarged mirror side would be helpful is because when someone goes to a hairdresser and wears glasses to see, they will remove them and place them in a safe place (purse, pocket of coat, or the shelf of the station...). When done the stylist tries to show you the back when done, all you see is a blur depending on how bad your eyes are. That enlarging side is helpful to keep you from scrambling for your glasses, delaying your answer to the stylist. I have gone through that question dance too many times and then had to grab for my glasses because they only had a regular mirror.
