[SOLVED] Separating Morph into Body and Head Morphs
magikhs
Hello!
So, I've got this G8F full-body-morph:
I'd like a separate body-only morph slider of this, just everything from the neck down, but with no changes to the head shape at all.
I've tried Shape Splitter, YouTube tutorials (anything between D-Forms and even exporting this as an .obj, separating and then importing it back into Daz) and read several related topics, but no dice. It's been absolutely exhausting! Mainly because I'm a complete Blender noob, but also when I was able to separate this into Body and Head morphs, for instance, with the excellent Shape Splitter, I'd run into issues like - it'd also reset whatever head morphs I've got on a character back to the default G8F head, totally killing the work I've done on that character's head. Also the slider I'd generate using Shape Splitter would not show up for any character other than the one Shape Splitter was used on, no matter where I saved it (is it really saved anywhere?).
Help, please? I can provide the files if anyone would like to take a stab at it, I'd appreciate it.
Thanks in advance! ^^
Post your G8 morph someplace where I can download it. Send me a PM with a link to the file and I'll attempt to split it for you. I've had good luck in the past with the head split D-Former that comes with the G8 Starter Essentials package. If you've built a height change into the character morph, that could possibly cause problems.
[This thread may be closed.]
Thank you for your incredibly generous help @barbult, from the bottom of my heart. You're the absolute best! ^.^
I realized the split morphs needed to have their rigging adjusted to shape, so I sent you a link to an updated version of the files.
