texture of the breasticular
Hello,
I need some help because I can't seem to apply my character's skin texture to the Bresticular pack; do you know what might be wrong?
  • felisfelis Posts: 6,546
    I don't have it.
    But my guess is.
    That you first must check if the character (skin) uses the same shader as Breasticular, and if not apply the correct shader to breasticular.
    Then copy the Body surface material (from the character) and apply it to Breasticular.
  • StellarStellar Posts: 49
    felis said:
    I don't have it.
    But my guess is.
    Do you mean something like this?
    https://gofile.io/d/WcwlVL
    I just tried it with another character and it works fine. Maybe there's a trick I can use by activating the morph on my original character and deactivating the morph on the character that works?
    Good you got it working on another character.
    You should be able to apply any morph to a character of the same generation.
    Regarding your video, you should just have copied the body surface, but it worked because Breasticular also uses Body surface. But it looks like there is a tiling problem.
  • evilded777evilded777 Posts: 2,549
    spram said:
    Hello,
    Breastacular should come with a script for that. All of his geografts do...should be called something along the lines of Material Copy.
  • crosswindcrosswind Posts: 10,319
    spram said:
    felis said:
    I don't have it.
    But my guess is.
    Besides the geoshell for Breastacular, is there any other geoshell on the character ?
    edited June 29
    crosswind said:
    spram said:
    felis said:
    I don't have it.
    But my guess is.
    I don't think so. Where can you see that?
    Post edited by Stellar on
    evilded777 said:
    spram said:
    Hello,
    Yes i has use the material copy, You can see the steps I took below.
    Before :
    After :
    With the material copy :
    After the render :
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Do you have an alternative genital applied? Many of those add a shell.
    spram said:
    crosswind said:
    spram said:
    felis said:
    I don't have it.
    But my guess is.
    Because from the video you attached, it looks more likely a typical issue when there're geograft + multiple geoshells on the character ~~
     In Scene pane, type shell in the filter field on the top, see how many geoshells you can find in the list.
    crosswind said:
    spram said:
    crosswind said:
    spram said:
    felis said:
    I don't have it.
    But my guess is.
    Yes i have only that :
    But I tried recreating the character with nothing equipped except the "bresticular," and it works. I think I'll just remake the character from scratch—I don't mind. Thanks anyway, though.
    edited June 30
    edit : After remaking the character, the issue turned out to be eye makeup and the scar on the face that wasn't applying the skin texture to the added breasts.
    The eye makeup and scar are likely one or two geoshells.
    Breastacular is a geograft, the surfaces of a geograft are automatically created on all geoshells on the figure, so you either hide the graft areas by turning off shell Visibility... or correctly tweak the settings on their surfaces in Surfaces pane, e.g. set Cutout Opacity to 0 ~~
  • AmnesiacThiefAmnesiacThief Posts: 31
    I'll just add that the material copy scripts for this vendor's products currently do not work in Daz 6. He/she has a link to a dropbox for new scripts to use in Daz 6, and I expect the full product packages themselves will eventually be updated to include the fix.
  • gelstatgelstat Posts: 41
    edited July 6
    Meipe update Copy material for daz 2025 but work with daz 6
    G9
    https://www.dropbox.com/scl/fi/89mfspov1ndh8s6lp9aum/G9_ScriptFixes_2025.zip?rlkey=91k0c06n86530kzwjasowov3v&dl=0
    G8
    https://www.dropbox.com/scl/fi/h7v5sdfpw9k0bv9lsrwnb/G8F_G8M_ScriptFixes_2025.zip?rlkey=g2mtyuenpurve4mm6np6gdowz&dl=0
    Source : https://www.renderotica.com/community/forums.aspx?g=posts&t=282700&cmsg=0&cmsn=#post559715
    Even without that, just save it as a shader named “body” on the character and apply it to the “Body” breastacular—there shouldn't be any issues with the UV selection.
    Shell fix v3 are available to for daz 2025/6
    766 x 568 - 291K
    Post edited by gelstat on
