another obj mtl file question
OK
my meshes created by Hunyan 3D AI and converted fron glb to obj with PConPlanner the other day, import into DAZ Studio textured
today's batch don't
both sets are in runtime textures folder so D|S can refind them after saving duf files
# created with pCon.planner
newmtl mat__473a7d2e
Ka 0.41350016 0.35234278 0.35280597
Kd 1 1 1
Ks 0 0 0
Ns 0
illum 2
works
newmtl mat__3118bd15
Ka 0.46559992 0.38622758 0.34440079
Kd 1 1 1
Ks 0 0 0
Ns 0
illum 2
doesn't
can anyone see what I am missing?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,803
    edited June 26
    this gets stranger, the first figure I generated today loaded textured
    newmtl mat__f35b7851
    Ka 0.35568827 0.18462712 0.13991484
    Kd 1 1 1
    Ks 0 0 0
    Ns 0
    illum 2
    not hard to drag and drop the textures into base colour on iray uber, but still
    1920 x 1040 - 404K
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Are those the surfacews names? I can't recal the details for MTL files. Do they match the surface names shown in DS, and the original names from creation?
    edited June 26
    not on my PC right now
    (in bed on iPad)
    but PConPlanner actually generates those png files from loading the glb file
    I did exactly the same thing, (it is my default program for opening glb files)
    just export an obj after it loaded it
     oh one difference
    my first 10 or so files were generated from image prompts
    the rest from descriptions but the first one loaded textured
    just the ones after didn't, very mysterious
    I am guessing you are right, the surface names or something doesn't match
    would be one of the other programs not D|S
    will check later
    Check for spaces in the group/surface names - strictly OBJ doesn't allow those 9theya re treated as separators) but some applications allow them. I can't see a space in the name in the MTL, though.
    edited June 27
    the material names match
    I am stumped
    its OK but this doesn't help me one bit in knowing what D|S looks for in the mtl file
    I even tried renaming the texture and editing the mtl file
    sharing 2 zips, one works, one doesnt
    zip
    zip
    emperor.zip
    4M
    zip
    zip
    Roman peasant.zip
    4M
  • crosswindcrosswind Posts: 10,355
    edited June 27
    When saving OBJ file with MTL, never leave any space character in between words. Type a dash instead, e.g. Roman peasant.obj, has to be Roman_peasant.obj. Then MTL file will be Roman_peasant.mtl that can be correctly loaded.
    In your case, if you rename Roman peasant.mtl to Roman_peasant.mtl, then open Roman peasant.obj with Notepad++, line 3, replace mtllib Roman peasant.mtl with mtllib Roman_peasant.mtl, it'll also work.
    Post edited by crosswind on
    oh wow, thats it,
    you solved it yes
    my first lot were all numbers with _because that's how Gimp saves files split from images namely the Colosseum equites billboard texture I used
    my prompt generated meshes were all Roman something except the emperor one that works!
    Great ! yessmiley
  • BejaymacBejaymac Posts: 2,014
    edited June 27
    Just to add that this isn't new behavior by DS, I've been using DS for roughly 20 years at this point and it's always hated spaces, and not just in pathways and file names, spaces in mesh group names and in Surface names have the same effect.
    Some programs give you generic surface names like Material 01, Material 02, Material 03, all DS sees is Material and lumps them all together as one surface at import.
    Post edited by Bejaymac on
    That is, as I said, part of the OBJ definition - space is a separator. I wasn't aware it affected pathnames too (though they would require quotes even in an OS command line to avoid their being treated as separate entities).
