another obj mtl file question
WendyLuvsCatz
OK
my meshes created by Hunyan 3D AI and converted fron glb to obj with PConPlanner the other day, import into DAZ Studio textured
today's batch don't
both sets are in runtime textures folder so D|S can refind them after saving duf files
# created with pCon.planner
newmtl mat__473a7d2e
Ka 0.41350016 0.35234278 0.35280597
Kd 1 1 1
Ks 0 0 0
Ns 0
illum 2
works
newmtl mat__3118bd15
Ka 0.46559992 0.38622758 0.34440079
Kd 1 1 1
Ks 0 0 0
Ns 0
illum 2
doesn't
can anyone see what I am missing?
this gets stranger, the first figure I generated today loaded textured
newmtl mat__f35b7851
Ka 0.35568827 0.18462712 0.13991484
Kd 1 1 1
Ks 0 0 0
Ns 0
illum 2
not hard to drag and drop the textures into base colour on iray uber, but still
Are those the surfacews names? I can't recal the details for MTL files. Do they match the surface names shown in DS, and the original names from creation?
not on my PC right now
(in bed on iPad)
but PConPlanner actually generates those png files from loading the glb file
I did exactly the same thing, (it is my default program for opening glb files)
just export an obj after it loaded it
oh one difference
my first 10 or so files were generated from image prompts
the rest from descriptions but the first one loaded textured
just the ones after didn't, very mysterious
I am guessing you are right, the surface names or something doesn't match
would be one of the other programs not D|S
will check later
Check for spaces in the group/surface names - strictly OBJ doesn't allow those 9theya re treated as separators) but some applications allow them. I can't see a space in the name in the MTL, though.
the material names match
I am stumped
its OK but this doesn't help me one bit in knowing what D|S looks for in the mtl file
I even tried renaming the texture and editing the mtl file
sharing 2 zips, one works, one doesnt
When saving OBJ file with MTL, never leave any space character in between words. Type a dash instead, e.g. Roman peasant.obj, has to be Roman_peasant.obj. Then MTL file will be Roman_peasant.mtl that can be correctly loaded.
In your case, if you rename Roman peasant.mtl to Roman_peasant.mtl, then open Roman peasant.obj with Notepad++, line 3, replace mtllib Roman peasant.mtl with mtllib Roman_peasant.mtl, it'll also work.
oh wow, thats it,
you solved it
my first lot were all numbers with _because that's how Gimp saves files split from images namely the Colosseum equites billboard texture I used
my prompt generated meshes were all Roman something except the emperor one that works!
Great !
Just to add that this isn't new behavior by DS, I've been using DS for roughly 20 years at this point and it's always hated spaces, and not just in pathways and file names, spaces in mesh group names and in Surface names have the same effect.
Some programs give you generic surface names like Material 01, Material 02, Material 03, all DS sees is Material and lumps them all together as one surface at import.
That is, as I said, part of the OBJ definition - space is a separator. I wasn't aware it affected pathnames too (though they would require quotes even in an OS command line to avoid their being treated as separate entities).
