All Genesis 8 male figures have lost their compatibility
Navigator_ITA
Hi.
I think the problem started after downloading some free content from RenderHub, but I'm not 100% sure.
Anyway, all the Genesis 8 male figures don't show their compatibility with clothing, poses, and expressions when selected. They end up looking like creatures.
I processed and reimported the metadata, and I reinstalled Genesis 8 Essentials, but nothing.
Have you checked Filter by Context in Smart Content ?
Sure...I can use the content for Genesis 8 male figures in Smart Content only if I don't check that filter.
I am not sure what you mean - compatibility settings have nothing to do wiith how a character looks, and theya re what drives the Filter By Context feature which you say is working. I suspect that you may have mis-idnetified the issue (if all Genesis 8 Male figures load looking like a creature that sounds like a morph saved with a non-zero default).
Maybe I expressed myself poorly or wasn't very clear. I'm attaching 4 images to avoid misunderstandings.
There is probably a product hijacking G8M compatibility base.
With G8M selected, right click on the scene panel then on (I think) Scene Identification and share a screenshot of the window that'll open.
In scene identification, something is wrong.
I don't have that product, but a mistake was made while creating the metadata for it.
To solve the problem on your end:
It should fix the problem.
If you feel lucky, you can open a ticket with Daz, hoping for a fix: metadata are Daz responsability.
The strangest part in your problem is that re-installing Genesis 8 Starter Essentials should have fixed it as far as I know.
It works! Everything is back to normal. Thanks Elor!
