help! missing (essential) pose reset/zero utility
jardine
so this is a product i've had once upon a time. i have a new box with a 5080 GPU, and i'm trying not to reinstall any stuff that's non-genesis-9-related, with some exceptions. like poses.
but this is a product i once had bookmarked as a regular part of my workflow. i know it's a genesis 8 product, because i had to use zevo's pose converter to apply it to genesis 9 figures. it might be a genesis 3 product, but i don't think so.
i suspect the product name doesn't contain the word 'poses', because i've searched DIM for such.
it's not devon's, nor is it riversoft arts's.
it breaks down the pose zeroing/resetting clearly by nodes. zero Head. Zero Neck. and so on.
i'm at my wit's end looking for it. does my vague description ring any bells for anyone?\
thanks and best wishes,
j
The only one I have like that is for G9: https://www.daz3d.com/jw-pro-pose-reset-for-genesis-9
Have you tried searching DIM for 'reset'?
This is my goto pose symmetry, mirroring and resetting tool, and some of what you said does match, so could it be this?
https://www.daz3d.com/daz-studio-4-scene-tools-set-3--pose-symmetry
You said it dos not include the word 'poses' but if its not Devon or Riversoft, only two other products come to mind that include some zeroing/reset feature:
-Ultimate pose master: https://www.daz3d.com/ultimate-pose-master
-Pose fusion: https://www.daz3d.com/pose-fusion-for-genesis-to-genesis-8
You could just save a few partial poses off of a zero'ed figure - couple of minutes tops.
I use Pose Fusion for G9. Also, any single figure Zeddicus pose asset contains zero pose assets for partial poses.
And other times, I select child on a hand, click all under parameters, and I zero the bend, twist and side-side parameters directly. :) :)
There's also Ultimate Zero by RiverSoft Art. It works with all the generations.
Ultimate Zero used to be my go to. But it's a bit too powerful. These days I only use it when I have a weird morph I can't track down. It will find it.
