Adding to Cart…
Yep. I've been distracted by RL and other projects -- so many projects. Hopefully I can get back to this in a couple of weeks.
Hi gang,
Here is the next update of the Script Server, v2.5.0. Release v2.5.0 — Interaction Posing, IK Solver, and Body Measurement Fixes · bluemoonfoundry/daz-script-server
Updates include:
InteractionRecipefrom a pair of figure labels: Available presets:build_sit_recipe,build_touch_recipe,build_kiss_recipe,build_fight_recipe. All presets produce anInteractionRecipethat serialises to JSON and can be stored and replayed.docs/examples/body_measurements.py)"MadisonG9") now discards slices above 1.35× the median before selecting the bust peak.--figure-typeflag — passG9F,G9M,G8F,G8M,G8.1F, orG8.1Mto force a calibration entry when auto-detection cannot determine figure gender from the scene label.Extended Test Suite
tests/package (test_dazpy.py,test_api.py,test_dazpy_integration.py,test_performance.py,harness_integration.py).tests/README.mdadded — documents every test class and individual test across all five modules.tests/harness_integration.py) covers the full interaction posing pipeline end-to-end;--autoflag for CI/smoke use.Sweet and with DS6 SDK released we can complie this to work in DS6. Thanks for the added features. Looking forward tot he updates.
Ugh. I'm still having a heck of time installing DS6 (keeps getting stuck in Retry) and the SDK doesn't show up in my IM even after following all the steps people have outlined. Very frustrating.
But as soon I get over those hurdles for sure I'll include DS6 versions.
FYI, I've added automatic nightly build of the repo so people who want to check out the bleeding edge stuff can do so prior to the formal releases.
See Releases · bluemoonfoundry/daz-script-server
The releases going forward now include the DLL for Windows as well as dylibs for Mac OS Intel and Apple Silicon.
Hi gang,
We are now building test versions of the Script Server plugin for DS 4 and DS6, for Windows, MacOS Intel, and MacOS Apple Silicon. These artifacts are available in the Nightly build for present, while we continue testing them. They will be rolled into the next version as part of the standard release. Remember that if you want to use a newer version of the plugin you must remove any old DLL or dylib file first!
See the Artifacts section of the Nightly release here: https://github.com/bluemoonfoundry/daz-script-server/releases
Works great in DS6. Thanks for the new samples. Your project is moving along nicely thanks for sharing.
Hi gang,
So it's been a lot of work over the last couple weeks that I want to share.
The Script Server version 2.6.0 is released for Studio 4 and 6, for Windows, MacOS-Intel, and MacOS Apple Silicon. See here Release v2.6.0 · bluemoonfoundry/daz-script-server
The Studio MCP Server 0.4.0 is released as well, and it works with Script Server 2.6.0+. See here bluemoonfoundry/daz-mcp-server: MCP server wrapping the DazScriptServer HTTP plugin for DAZ Studio
The README contains a substantial information about the MCP Server and how to to use it.
One thing I thought might be useful is an example of a conversation I had with Claude that used the MCP server to drive DAZ Studio. Here the is the transcript of the conversation:
https://claude.ai/share/5fca5cd1-3861-42d9-b407-b2732bf08f1e
As we can see from the transcript, the end-to-end workflow seems to work but there are obviously places where the MCP Server doesn't get things right or doesn't understand. Which is okay, but I'm using this to essentially teach Claude when it makes mistakes or doesn't understanding things. The file SKILL_DAZ_STUDIO.md captures some of those lessons learned, which can then be given to Claude, or any other LLM, to make sure that going forward it doesn't make the same mistakes (fingers crossed). As I continue to make improvements, some of these lessons learned will get baked into the server code itself.
So try it out, let me know what works and what doesn't and what you'd really like to see feature-wise. If you are a newbie to LLMs and MCP Servers and this stuff doesn't make sense but sounds cool, send me a DM and I'd be happy to guide you through the process of getting started so you can play with this.
[Edit: MCP .4 requires ScriptServer 2.6.0+]
@sidcarton1587 please check your PM for the script
Hi gang,
For those who are tracking I'm going to be publishing ScriptServer 2.7.0 and the updated MCP Server 0.5.0 in the next few days. A lot of improvements, bug fixes, and some interesting integration examples.
As I am putting finishing touches on this release I am looking forward to improvements for Version 3.x and one of the things that I'm thinking about is adding a Python server, either as part of Script Server or a seperate plugin, and wanted to get some feedback on whether this would be something that could be useful. The general idea is that you can "call out" from a DAZ script in a standard way Python scripts that execute and send back results to the DAZ script. In its simplest form, this would be similar to the Script IDE pane, except that you could write Python code instead of DAZ script code. In more advanced operations, this would allow you to send data from DAZ Studio to Python which could then do computations, or communicate to an external service from there (e.g. Blender or some other tool), and return results or information back to the DAZ Script (or use Script Server to do automations in Studio based on the results).
I'm not entirely sure what the final architecture will look like, so all of this is subject to change. Here are some potential showcase concepts of what could be possible (full disclosure: they were edit and formatted by Gemini). In some cases, you can have the Python server work with the Script Server in a loop, so you don't even need to write the script response yourself. Anyway, still mulling through concepts. Welcome discussion.
Showcase 1: The "Instant Voice Actor" (Audio-to-LipSync Animation)
Creating realistic mouth and facial animations to match a voice-acting track is traditionally a tedious, frame-by-frame process.
The Concept: Drag and drop an audio file (.wav or .mp3) of a voice line. The plugin automatically generates natural lip-sync and facial expression animations on the active figure's timeline.
The Tech Stack:
Whisper (by OpenAI) or Wav2Vec2 (by Meta) to analyze the audio file, perform phoneme alignment, and detect speech timing.
A Python mapping dictionary that translates phonemes (like "ah", "ee", "oh", "th") directly to DAZ's native viseme and mouth-shape morphs.
Why it Showcases the Power: It takes a highly complex task (audio processing and phoneme extraction), wraps it in a simple drag-and-drop UI, and outputs frame-by-frame timeline keyframes in DAZ Studio.
Showcase 2: Text-to-PBR Material Generator (Stable Diffusion)
Creating custom textures (like rusted sci-fi armor, worn leather, or detailed skin) usually requires opening external painting software like Substance Painter or Photoshop.
The Concept: Select a surface on a DAZ object, type a text prompt (e.g., "highly detailed medieval plate armor, scratched steel, brass engraving"), and hit generate. Seamless, tileable textures are applied directly to the surface in real-time.
The Tech Stack:
A lightweight, local Stable Diffusion instance (or a call to an online API) to generate seamlessly tileable texture maps.
OpenCV to generate corresponding normal, roughness, and metallic maps from the diffuse output.
dazpy to dynamically construct a new Iray PBR material, assign the textures to the correct channels, and apply it to the selected geometry.
Why it Showcases the Power: It shows how DAZ can be integrated with generative AI workflows, allowing artists to texture scenes dynamically using natural language.
Showcase 3 : Dynamic Weather & Lighting Sync (API Integration)
Setting up realistic environment lighting to match a specific mood, time, or location is a trial-and-error process.
The Concept: Type in a real-world city (e.g., "Tokyo, Japan") or select a preset mood. The plugin syncs DAZ’s Iray environment dome, sun position, tone mapping, and fog parameters to match the actual, real-time weather and time of day in that location.
The Tech Stack:
The requests library in Python to query real-world weather and solar position APIs (like OpenWeatherMap and SunCalc).
Python converts the solar elevation and azimuth angles into DAZ's Iray infinite-distant light directions.
If the API reports "Cloudy," Python adjusts the environment map intensity and adds volumetric fog to simulate overcast lighting.
Why it Showcases the Power: It demonstrates how easily Python can bridge DAZ Studio with the wider internet, enabling real-world, data-driven scene generation.
That would be very useful to have this type of expansion in Studio. Looking forward to the updates.
Hi all,
I went ahead and publish version 2.7.2 of the Daz Script Server
See here: Release v2.7.2 · bluemoonfoundry/daz-script-server
The dazpy Python package is now published on PyPi, so you can `pip install dazpy` to install it seperately to support writing your own script code.
Here is the dazpy API documentation: dazpy — DAZ Studio Python SDK — dazpy 2.7.2 documentation
And here is the HTTP API documentation: DazScript Server — HTTP API Reference
As always, the best place to comment on and request new features and bug fixes is on GitHub:
Issues · bluemoonfoundry/daz-script-server
bluemoonfoundry/daz-script-server · Discussions · GitHub
