New Year, New Sales Thread: Report Issues Here 4 "Reporting Only"
1…3738404243…87
  • Richard HaseltineRichard Haseltine Posts: 111,696
    Dareshiranu said:
    joanna said:
    donniekeidic said:
    So if I sign up for a new membership right now will i be eligible to use the STUDIO-6-PREP coupon code aftewards? Or is it only for people who were already members before today?
    According to the small print in DIM, you have to have been a member before June 4th to be eligible.
    So, I've been a member for years - lots of them. I finally decided to bag my remaining four years of Plus and go for Premiere, for which I got very little in return IMO - loaded up DIM to download some new purchases and then discovered the PREP coupon. Sounded nice, especially since I "have" been a member for a long, long time. However... the coupon is declared invalid. Quite disappointing. I don't enjoy being teased.
    I think you need to open a Sales support ticket for this.
  • donniekeidicdonniekeidic Posts: 192
    Ok, thanks. That seems fair honesty, I just wanted to find out. The 50% off is still a good deal.
  • WolfwoodWolfwood Posts: 998
    Yes is a good deal. And on time, what you saved with that 50% will be worth a lot more than the 200 coupon as long as you spend smart
  • Phoenix1966Phoenix1966 Posts: 2,015
    STUDIO-6-PREP also not working for me. Not sure what the issue is. My cart has only non-new Daz Originals, which I think is what is required. Is there a minimum purchase amount needed to trigger the coupon?
  • barbultbarbult Posts: 27,598
    There are some exclusions.  I had to enlarge the message window in DIM to see them. Not valid on New Releases, Licenses, Memberships, Gift Cards. One use. Must be a member prior to June 4. I didn't see any minimum. I put the coupon in the cart and it worked with just a couple things. Then I kept adding stuff. It looks like you are doing it right, but if you add one of today's non-DO new releases, it will give you 20% off on the DOs, which makes the coupon go farther.
    Why is the text of your message so pale gray?
    I've met all the criteria and absolutely no luck.
    No idea about the text. Maybe because I copy and pasted the code?
    edited June 5
    @Phoenix1966 I sent you a personal message.
    Post edited by barbult on
  • memcneil70memcneil70 Posts: 6,137
    Just want to note that someone at Daz fixed my metadata issue from my 4 June purchase. And I had no problems with downloading my 5 June purchase. The Daz Team came through and if management is around, I just want to pass on my thanks for a great team.
    No idea where to ask this, but can someone explain why so many threads show 1 or 2 views, when there are sometimes hundreds of comments? Are the forums broken? Is this normal. Yet others show thousands of views, so obviously some do appear to work.
    The forum is broken.
    There are in fact threads on ths, if search worked, and ideally this thread should not have off-topic posts since it is monitored for sales issues. But yes, the view count used to work but has been broken for quite some time now.
  • rokkrrokkr Posts: 394
    edited June 6
    studio-6-prep is not working right... I'm Premier, it says I'm eligible for $200. My cart has $222.38 -- all from the link (https://www.daz3d.com/daz-originals?utm_medium=dim_footer_targeted&utm_source=dim), so I'm not adding anything invalid. I put the coupon and the price drops to only $108.07... Then, I clean my cart, add a random item from the list -- "coupon not valid." I try to add more items, and then I discover the problem: not all items from the list are set to accept the coupon. For instance, I added those four random items:
    XI Commercial Transport Van
    Viking Tents 2
    dForce Tony Hair for Genesis 9
    Viking Huts 2
    Only the Viking Tents 2 accept the coupon -- the others keep their listed prices. I hope the coupon lasts, at least, until tomorrow, otherwise it'll have been quite tricky...
    P.S.: Oh... It doesn't apply to either new items of Daz +... In the covered part of the banner... But why are they on the list? Quite annoying, especially since there are no "hide new releases" nor "hide Daz+ items" buttons...
    Post edited by rokkr on
    edited June 6
    Viking Tents 2
    Viking Huts 2
    @rokkr you need the Utilitarian Bookmarklet  . It is free and has both of those filters.
    765 x 82 - 13K
  • caravellecaravelle Posts: 2,784
    edited June 6
    I chose Marida Gown Outfit Textures from 'Today's Specials' and additionally took today's Daz Deal, LY Renley Shaw. Both articles appear in the list of my product library, but when I select the Marida Gown Textures, LY Renley Shaw appears instead. I can't get close to the textures; of course it's impossible to download this article either. Does anyone else have this problem?
    Post edited by caravelle on
  • ElorElor Posts: 4,162
    Does this link get you to the Marida Gown Outfit Textures?
    https://www.daz3d.com/downloader/customer/files#prod_73633
  • Cris PalominoCris Palomino Posts: 13,010
    I can't find Marida Gown Outfit Textures in the specials.
    That's a link to your product library. It won't help other people.
    edited June 6
    73633 is the product's SKU and AFAIK, the link should be the same for everyone:
    https://www.daz3d.com/dforce-marida-gown-outfit-textures
    I don't know if you own the Marida textures pack, but we both own FK Artissane. That product's SKU is 114562, and the link in my product library is this one, which should work for you too:
    https://www.daz3d.com/downloader/customer/files#prod_114562
    Post edited by Elor on
    edited June 6
    The link to 114562 just opened my product library. It didn't select the specific product. I don't know why. Maybe because I am on my phone, and lots of Daz web pages don't work on mobile. We are probably getting into too much discussion for the reporting thread.
    It does! Thank you, Elor!
  • LeanaLeana Posts: 13,564
    Do you own that particular product?
    edited June 6
    I own the Fabiana product, but not the clothing texture product. I think I'll try the link later when I am on my computer. I can't see much on the phone. Things like search in forums doesn't work. It goes to the store. The Vendor selection doesn't work either.
    That's weird. I got it out of this category, and with the coupon the discount also worked. With Elor's 'magic trick', the product is now also displayed correctly in my PL. Thanks, Chris!
    I own Fabiana's set as well, and this link also works.yes
  • 3DMinh3DMinh Posts: 296
    I'm on the premier monthly. Now how can I get the 50% off of the annual membership? Do I just upgrade to annually or I have to cancel first? Can I view which will be the amount charge to my card first? It's a huge amount for me and I don't want to be accidentally charged more ...Thanks.
  • Charlie JudgeCharlie Judge Posts: 13,641
    I went from monthly to annual by just changing to annual. At the end you should see the actual amount before it is charged.
    Is this the correct amount? I'm confused whether it's 95.83 or 199? Is there a final confirmation after this, because I only see the field to input my card's info.
    696 x 442 - 31K
    That looks like mine did and my credit card was charged the $95.
  • butterflyfishbutterflyfish Posts: 1,810
    Same. The next screen had the full price, but I was charged the 50% off price.
    It works for me on my computer. It was the phone where it appeared not to work.
