Animation renders
I'm new to this. Just fooling around with it, trying to get the hang of it. I created a simple scene with a character transitioning through several poses. The sequence is 80 frames. The rendering seems to have gone fine but when I plug the sequenced images into Premier, it plays in ultra, ultra slow motion. A clip that should only take a couple of seconds takes nearly seven minutes to run.
Obvious, I've done something wrong either when I created the animation or in the render settings. I've tried both the movie render setting at the sequenced images render setting. Same problem.
Any ideas?
What is the fps set to?
30
